| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
How does a driver ( ie 12" sub ), create a 20 ft wavelength (50 hz)?
For some reason I can't get my head around how a driver moving in and out 1" creates the low tones/long wavelengths. I searched for an answer, but could not find one. |
#2 |
if you throw a little stone into water
how can those small circles can become so very big circles
lineup |
#3 |
Some good info here
The above link has some good info, I think it was designed for kids, but still good. |
#4 | |
Sound moves at ~1125 ft/sec --->13500 in/sec (13500 in/sec)/270in = (50 in/sec)/1 in (Speed/wavelength alway equals the frequency/displacement) The cone is transferring its low speed and low displacement energy to air which "communicates" the pressure at the speed of sound and therefore creates longer waves than the source is providing. Another way to word it is it is all time dependant, the speaker and the air both oscillate at the same frequency but the air moves faster and therefore cover more "ground". Hopefully that was written well enough to make sense, if not I'll try again later. |
#5 | |
The SPEED at which the driver moves in and out gives the TONE or frequency of the sound. The AMOUNT by which the driver moves in and out gives the loudness, or amplitude, of the sound. So, by saying the driver moves 1" in and out - this only gives an idea of the amplitude or how loud the sound "is". Hope this helps! Cheers |
#6 |
Wavelength:
Think of it this way: imagine a little red dot that travels horizontally at a speed of 1120 feet/sec. As the red dot moves (fast!), it also goes UP and DOWN, at a rate of 50 times per second. Question: How far apart are the PEAKS in position of the red dot? Answer: The dot moves up and down 50 times in a second - so the amount of time between PEAKS in position is 1/50 of a second - if the dot is traveling at 1120 feet per second, it would have traveled 1120/50 = 22.4 feet There's your wavelength (50Hz). Cheers |
#7 | |
The AMOUNT the driver moves and the resulting loudness are functions of frequency, if two drivers are moving 1"p-p but one is playing 20hz and the other is playing 40hz, the one playing the 40hz tone will be 4 times louder. His question is about the nature of sound and how a cone moving some small distance(ex. 1") can cause long waves(ex. 20') in air. And Im not sure if the red dot thing was an analogy, but it is generally confusing to reference vertical sine waves when discussing sound especially when the above link illustrates exactly how the air particles move. |
#8 |
Sound propogates at ~ 330 metres per second. Frequency = number of times per second. Wavelength = 330 metres per second / number of times per second. |
#9 | |
#10 | |
Hence the statement "the one playing the 40hz tone will be 4 times louder." And the statement The AMOUNT the driver moves and the resulting loudness... |
| Really basic TL question | weinstro | Full Range | 3 | 11th October 2007 05:16 AM |
| amp question basic rec | rebith75 | Solid State | 3 | 16th March 2007 05:43 PM |
| Basic RC Value Question | SRMcGee | Tubes / Valves | 6 | 13th August 2006 05:39 PM |
| really basic question | cuallito | Tubes / Valves | 6 | 15th April 2004 08:25 PM |
| really basic question | MbayAQ | Digital Source | 3 | 7th January 2003 12:57 PM |
| Page generated in 0.11939 seconds (83.72% PHP - 16.28% MySQL) with 10 queries |
