Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
DIY stereo cables, is this right?!?
Old 25th November 2006, 10:01 AM   #1
space-cake is offline space-cake  Israel
Default DIY stereo cables, is this right?!?
http://www6.head-fi.org/forums/showthread.php?t=52044
i just found this link during my search to see what type of cable should i use. i noticed that the guy is removing the shield and not connecting it to the ground terminal on the jacks - rather he uses the conductors. is this the right way to do this???
Old 28th November 2006, 12:27 AM   #2
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default Connections
Yes he is doing it right..If you think about it, what kind of electrical values do you think you would get if you hooked up that large "shield" conductor vs. that small wire...wouldn't you get an imbalance of values?...Like say a difference of impedance?
The "size" & value of the wiring should be the same as to avoid a host of problems.
________________________________Rick.............
Old 29th November 2006, 07:45 AM   #3
i think you base your answer on a phenomena where high freq. is moving faster than lower freq. over the same conductor.
all audio cables other than speaker cables have different conductors for groud / shield and and "hot" leads. in a PCB the ground traces should always be kept bigger over signal traces (you can check an amplifier PCB). i think that in the freq. that audio is at and the fact that these cables are very short AND the fact that the signal will be pretty close to line level the impedance difference between the conductors is simply irrelevent. I get the feeling that people who made these cables never found them problematic because they are simply too short to pick up static.
Old 29th November 2006, 07:56 AM   #4
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
For all my interconnect I use balanced cable with two cores and screen, wired with the core cables connected at both ends to signal and ground, but with the screen only connected at one end. It's called psuedo balanced.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
DIY stereo cables, is this right?!?Hide this!Advertise here!
Stereo in/multiple Stereo outs Circuit MartinByrne Everything Else 3 7th May 2009 01:11 AM
rg59 rca cables for car stereo?? HU to amp interconnect jton219 Car Audio 7 29th August 2008 11:04 PM
Reprocessed for stereo, Rechanneled for stereo and Duophonic oldheathkitphil Analog Line Level 3 29th February 2008 01:20 PM
ssabripo's DIY Interconnect cables: $200 cables for 1/10 th the cost! ssabripo Everything Else 3 26th October 2006 02:33 PM
cables for diy amps, preamps, and speaker cables ... paulspencer Solid State 5 3rd August 2004 07:14 AM
Copyright ©1999-2017 diyAudio
