Anything that I can do with my graphite? - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 23rd November 2006, 06:17 AM   #1
keantoken's Avatar
Default Anything that I can do with my graphite?
Hello, everyone.
I have this stash of graphite powder from when I was younger and was into forensics and stuff. I mercilessly raked out the entrails of many pencils which met their imminent doom at the end of an unused staple. Today I carry the priceless memorabilia in a small mechanical pencil lead container, while it waits for it's chance to break free and return the long-suffered pain and agony in which it endured before my ruthless rampage for fingerprint powder!
Anyways, I was wondering if there was any electronic application for graphite where I could improve the quality of a component or tweak the performance of a circuit. I have no clue about the physical properties of graphite, so I am wondering if it could be used for inductors in some way. could it be rubbed on to an inductor core and have some type of effect? It makes things look shiny when rubbed on, so maybe that could be utilized. Or maybe it could be used in a speaker, maybe, between the coil and the magnet to reduce friction or soften the sound. I do know that this powder is very soft, so I'm thinking that it could be used as some sort of solid lubricant, maybe to help connectors slide together more easily, but graphite is resistive, so I don't think that that would work very well.
Any ideas?
-keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 23rd November 2006, 07:56 AM   #2
pinkmouse's Avatar
I'm sure I read of graphite powder being used to coat mylar to make ESL panels. You might want to dig around in the ESL forum. Other than that, I can only think it would be useful for mechanical lubrication, but nowhere where its conductive properties would interfere with operation.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 23rd November 2006, 07:59 AM   #3
bulgin is offline bulgin  South Africa
Default Anything I can do with my graphite?
Hi
Isn't the stuff conductive? I think you should use some caution as to where you apply it. How about setting up a neighbourhood locksmithing biz, servicing seized locks?
bulgin
Old 23rd November 2006, 01:48 PM   #4
I_Forgot's Avatar
Most pencil lead consists of a mixture of clay and graphite. The softer the lead, the more graphite there is in the mix.
Yes, you can use graphite to coat diaphragms for ESLs, but it tends to make a low resistance coating which is not well suited for drivers that are to reproduce low frequencies. These days a spray called Licron is easier to apply and provides better results.
Graphite is available as a lock lubricant at any hardware store or WalMart. For about $2 you can get pure graphite in a much finer powder than you can ever hope to produce from pencils...
I_F
Old 24th November 2006, 02:25 AM   #5
keantoken's Avatar
I don't think I'll start a locksmithing thing, because too many people can just o to walmart and buy their own lubricant stuff. I don't like those packages that you get for the graphite at walmart, though. One small slip and POOF! Your covered with graphite and there's nothing left in the bottle! I'll have to remember that, though, 'cause if I ever want any fingerprint powder, I know where to go! I'm sure I'll find a use for it. I would think that it's too soft to go in my Xmod's (build-your-own remote racecar from radioshack) bearings, it would just let the bearings grind themselves to bits. Maybe I'll make a van de graph generator and see if I can make them float! Wouldn't that be cool...
Any word on the magnetic properties of graphite?
-keantoken
Old 24th November 2006, 02:31 AM   #6
jackinnj's Avatar
you could do an Al Jolson imitation
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
graphite based paint for ESL coating floydturbo Planars & Exotics 2 30th October 2006 11:05 AM
Graphite Foam Heatsinks? Check this out. Tony D. Parts 17 27th November 2002 03:18 AM
Copyright 1999-2017 diyAudio
