Hi all,
I've promised my old Mum that I'll have a look at her Sony all in one CD/MD/Tuner unit. It has an issue with the volume control that I'm not too sure about.
The control turns infinitely (it's meant to) and the output level is displayed graphically on an LCD from 0 to 35 units. The problem is that the level increase/decrease stalls at various points of the scale and sometimes won't move at all unless you turn it very slowly and carefully. Even then it's not guaranteed.
My question is - how does this unit work? As I say, you can keep turning it - it has no stops - and the scale currently takes about 40 turns to get to 'full volume'. I'm guessing the control 'pot' needs replacement, but what is it, exactly?
Any help would be greatly appreciated.
Cheers
Stuey
Cheers
Stuey
Thank you guys. I actually thought of a rotary encoder after seeing them in an electronics catalogue (Altronics here in Australia) but wasn't sure what these really were! I might have to search out some info as I'm interested in their construction.
I've 'popped the lid' but it's well hidden behind some PCB's. I'll properly unearth the unit and try some contact cleaner.
Thanks again!
Stuey
Thanks again!
Stuey
Just to complete the story, I removed the offending PCB containing the encoder, and it was a matter of seconds' work to bend back the tabs on the encoder and pull the casing apart.
The problem was merely an excess of grease, which I removed almost completely with some lighter fluid. I left a smattering behind, though.
It now works perfectly.
Thanks again.
Stuey
Thanks again.
Stuey
Cheers.
Andrew, it had three wipers similar to those in a potentiometer, bearing on two tracks of differently spaced alternating metal/insulator 'spokes'.
I guessed that the wipers were floating on the grease and not receiving the required pulse to provide the step increase in volume.
Stu
Stu
- General Interest
- Everything Else
- How does this volume control work?
