Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Solder through-hole penetration?
Old 13th November 2006, 11:47 PM   #1
Drew Eckhardt is offline Drew Eckhardt  United States
Default Solder through-hole penetration?
I used to use solid solder with liquid RMA flux. Didn't have problems soldering on one side of the board and having it flow through to the other.
I lost the flux and solder in a move, and bought a roll of Kester no-clean flux core solder. Penetration is spottier now - I'm probably touching up 1 in 20 joints on the component side of the board. Should I blame the switch to flux-core, the no-clean flux, or attrophied soldering skills?
I'm still using the same Metcal MX500 with a 700 degree tip (movers didn't loose that; my test leads and multi-meter are a different story).
Old 14th November 2006, 12:12 PM   #2
clem_o is offline clem_o  Philippines
Probably due to the flux-core. Liquid flux gets there (flows) before the copper has time to oxidize due to the heat of the solder / iron; flux core requires melting of the solder first, oxidizing the work partially.
Personally have not tried commercial liquid flux, but something I've worked with a reasonable number of times is rosin melted in a suitable carrier - it can be brushed on prior to soldering, aiding the solder flow.
Cheers
Old 14th November 2006, 03:38 PM   #3
Yep, that's the ticket.
I tried a flux pen with the same Kester no-clean flux and found that it solved my problem.
Old 14th November 2006, 11:06 PM   #4
Good to know!
If you decide to move in the future better put the good stuff in a bag and carry it yourself! :-)
Cheers
Old 20th November 2006, 12:51 AM   #5
mitwrong is offline mitwrong  China
mitwrong's Avatar
Send a message via AIM to mitwrong Send a message via MSN to mitwrong Send a message via Yahoo to mitwrong
Default soldering on PTH boards
Hi, Gents:
From my experience, It's not difficult to solder PTH boards.
First prepare rosin and dip into solvent until it becomes liquid rosin flux. solvent could be menthol spirit or thinner, Next get an air pump ( the one used in aquarium ) with the air stone. Before soldering, pour rosin flux in plastic bowl with the air pump on, then you will find rosin bubble flows at the top part of the bowl, place the PCB ( to be soldered ) over the bubble, the rosin bubble will cracked under the PCB, and the holes were filled with a thin film of rosin, then insert component and solder, this way, you will find the solder flows nicely up and down the holes. If dip solder to be applied, do the insertion before rosin flux, then the PCB will
be more soldered professionally.
WE SOLDER ACCORDING TO IPC SPECIFICATION
Old 20th November 2006, 01:18 AM   #6
Interesting technique! Thanks!
Cheers
Solder through-hole penetration?Hide this!Advertise here!
PCB Hole Size ptah Parts 10 30th November 2006 01:51 AM
What to do when your hole is a bit big? tommytube Multi-Way 6 13th September 2005 02:08 PM
Crossover hole joelives Multi-Way 10 29th June 2003 08:27 AM
help...drilled hole too big ultrachrome Parts 16 15th April 2003 04:07 PM
Copyright ©1999-2017 diyAudio
