| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hi folks, I wonder if anyone can help. My Windows box just fell over spectacularly, and I had to reinstall XP. I'm using a S/H Audigy card that didn't come with the application CD, but as before I downloaded the drivers from Creative and got up and running. However, I seem to have a bit of an issue, in that I can't get any signal on line in without turning up the Line In channel on the playback Volume control panel. Surely this is just an internal tap on the signal, and not another input control? I don't seem to remember having to do this before when I was running it, but I used quickmix when I first set it up and can't recall the exact settings I had.
Any ideas?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#2 |
And the record settings:
#3 |
does it not have a booster tick box under the advanced tab?
#4 |
On the line in, this is what I have:
#5 |
what do you mean by getting a signal on line in? do you mean recording it?
then, you have 2 choices: -in recording, select "what you hear, then in "playback" select line in -in recording, select analog mix, then in advanced you certainly have to select line in btw, since you're using a soundblaster soundcard, you'd rather use the kx drivers set if your card is compatible, they are soooo much better
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease |
#6 |
What do the KX drivers do that the Creative ones don't?
#7 |
http://kxproject.lugosoft.com/index.php?skip=1
asio with lower latency, custom routing of signals, the ability to send a completely different signal to every jack connector (every jack appears as a standalone stereo device in windows) and the list goes on
#8 |
Thanks.
Do they work with Speaker Workshop?
#9 |
I assume so, if speaker workshop uses the soundcard like a windows driver, that's ok
if it uses special tricks available with creative labs drivers, then it couldn't work. but I think it works, you'll still have a soundcard seen as a windows multimedia device. you'll just have much more possibilities (I think you can even play one file to all outputs, and define your own code to apply effects to specific outputs) an example could be a low passed output on the jack1, band pass on jack2 and high pass on jack3
#10 | |
Hear the real thing! |
| Upgrading from Audigy 2ZS? | cjv998 | Digital Source | 4 | 17th July 2007 02:41 AM |
| Anything about the Audigy 2zs PCMCIA ?? | youyoung21147 | Digital Source | 0 | 15th October 2005 01:09 PM |
| Bl**dy Audigy... sugestions, please! | sobazz | Everything Else | 12 | 7th March 2004 11:48 PM |
| More Audigy 2 Warning | fmak | Digital Source | 5 | 9th February 2003 01:49 PM |
| Creative Audigy 2 | fmak | Digital Source | 15 | 26th January 2003 07:29 PM |
| Page generated in 0.11023 seconds (81.29% PHP - 18.71% MySQL) with 11 queries |
