| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 |
Hi, Guys
With my experience in 78/79 series regulator, it is better to parallel a .1uf cap. with the input & output filter cap. If in the cct like split supply say + & - dc out in cascade, a diode like 1n4004 shunted in the output side, thus protects the +ve side voltage flows to the -ve side and vise vera. therefore U should put two diode in both + & - side with reverse polarity direction. that means the the diode is not in the dc shorting direction. another way is to give a load like 10 ma to both + & - output, It makes the regulator more stable. the best way is to connect 2 leds with 2 resistors to limit the current flow thru the leds. usually led draws about 10 ma current. hope the above method can give u a Help. |
| Lithos regulator - A new super regulator? | peranders | Parts | 7 | 8th May 2008 02:01 PM |
| Switching 230 Volt Transformer to 120 Volt | OMNIFEX | Parts | 10 | 6th April 2008 04:34 PM |
| 12Mhz crystal oscillator - 3,3 volt regulator | ErikdeBest | Swap Meet | 0 | 27th April 2006 11:02 PM |
| 5 volt version of the Updated super regulator. | audiodoc | Parts | 18 | 27th March 2006 04:32 PM |
| Brazil, and some strange laws, not too much strange! | destroyer X | Everything Else | 0 | 11th September 2004 12:38 PM |
| Page generated in 0.05801 seconds (70.28% PHP - 29.72% MySQL) with 10 queries |
