| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hello guys,
I am trying to install a Dell 922 printer. During the installation a "microsoft visual c++ runtime library" error comes up saying there was a "Runtime Error! Abnorman program termination" with the file DLBTPSWX.EXE I cant find the file on my PC so can someone send it to me???? Thanks all Lawrence
<a href="http://www.danasoft.com"><img src="http://www.danasoft.com/sig/lawbadman.jpg" border="0"></a><div style="font-family:arial,sans-serif;font-size:11px;"><p>Sign by Danasoft - <a href="http://www.danasoft.com">For Backgrounds and Layouts</a></p></div> |
#2 |
I also need another file:
dlbtaiox.exe Would someone be so kind as to send me the file? send to: lawry200 at yahoo dot com Thanks
#3 |
What OS do you use?
The files should be on the installation disk. /Hugo |
#4 |
OS is XP.
I dont have the installation disk, it dissapeared. I downloaded the installation file from Dell web site. I have been installing and reinstalling with no luck. I keep getting the "Runtime Error! Abnorman program termination" with the file DLBTPSWX.EXE I also get the same error message when I press the "Scan" button on the printer. Does anyone have a clue as to what the problem might be? Thanks Lawrence
#5 |
Banned
you need to redo the installation thats for sure
installation problem or you could have a virus cheers |
#6 |
hi
try this google search link ( 761 hits ) shouldnt be too difficult to find a download for your Dell Photo Printer driver "Dell Photo AIO Printer 922" lineup lineup effective searches & webservices http://lineup.awardspace.com/
lineup |
#7 |
The safest is just to download it from the Dell website.
It might be a big file, hope you are not on dialup. /Hugo |
#8 |
I did download the file from Dell.
Installing and uninstalling does not work. At the end of the installation I get the same error message, which is also the same error message when I press the "Scan" button on the printer. The DLBTPSWX.EXE file is on the computer but it seems that it may be currupted. I am not sure.... Anyone have a clue???
#9 |
I have many times got my problems solved
by copying the exact error message, or a part of it and do a google search. most of the time somebody else has got into this error and is asking for help at some forum And I can see what advice they got so lets search for: "runtime error" "Dell 922" install here are the results of the web jury: seach results to get even more hits, you can try remove the 'install' and search for "runtime error" "Dell 922"
lineup |
#10 |
You must have Administrative rights to install the software but I presume you have since XP should warn you before installation if you haven't. Check to be sure though.
If it is an USB printer, always install the software before plugging in the hardware. Disable all virus scanners, spyware chasers, TSR's, name it... Other than that, I have no clue. Bad written driver? Call Dell support. If its a bug, they should have a fix. /Hugo |
| .slb file (translated library file)...! | spice freak | Solid State | 0 | 28th October 2008 03:20 PM |
| File Uploader - php script with file validation | lineup | The Lounge | 5 | 11th February 2007 09:09 AM |
| PDF file advice | cm961 | Everything Else | 9 | 9th August 2005 03:00 AM |
| .msa file extension | stevan1986 | Digital Source | 2 | 1st January 2005 08:17 PM |
| Page generated in 0.09982 seconds (81.73% PHP - 18.27% MySQL) with 10 queries |
