Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
12v to ttl converter
Old 8th October 2006, 05:52 PM   #11
xplod1236 is offline xplod1236  United States
xplod1236's Avatar
Send a message via AIM to xplod1236
Default More info
I will be taking 12v signals from the car (either 12v or 0) and feeding that into a microcontroller (run off a 5v supply), so the currents will be very small).
Poobah, I did google those phrases, but most of the results were 5v to 3.3v converters. Is there a specific name for the 12v devices?
Old 8th October 2006, 07:46 PM   #12
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
1. Voltage divider 12 => 5 V 10k + 10k
2. 4.7 V zener in parallel with the lower resistor, transient protection
3. Lowpass filter into the MCU. 100k + 100n Noise filter
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 65 pcb's in order. 59 paid.
Old 8th October 2006, 08:22 PM   #13
poobah is offline poobah  United States
poobah's Avatar
Xplod,
http://www.onsemi.com/PowerSolutions...?id=MC14504BCP
Don't be fooled by the fact the this says CMOS output only... It can be used for exactly this purpose. You just cinnect the output supply pin to your 5V. It really depends on the type of TTL you are using... regular TTL no... LS TTL yes.
Really, the circuits posted here are just as easy. In fact, when you consider you still need input protection... these circuits are probably simple to imlement.
Now... when you say 0 volts... do mean 0 Volts... or NO Volts, as in an open circuit? There is a diiference and TTL inuts will need a sink to ground to register a "low" state.
Old 9th October 2006, 12:11 PM   #14
clem_o is offline clem_o  Philippines
Do you want to just get the microcontroller to know if the car amp is on or off? If this is so, follow perander's suggestion... Check the microcontroller data sheet - most will switch logic states at the half voltage, i.e. 2.5V or greater is considered logic 1, anything below 2.5 is logic 0. If it's really "TTL" then anything from 2.0V to 5V is a logic 1, and 0.8V to 0V is logic 0.
Cheers
Old 1st June 2007, 02:13 PM   #15
eckertd is offline eckertd  United States
Would the resistor/zener setup work if I wanted to monitor a +12V square wave (20% duty cycle) on a laptop serial/parallel/USB port?
Old 7th June 2007, 09:09 AM   #16
Howdy,
Depends on the frequency of the signal. Using the parallel port, you might be able to monitor the presence of a signal, if the frequency is low enough... (or, with a high frequency, you'd probably miss a transition or two), but it should work. Serial would be more iffy, and USB - well, writing a driver to talk to the USB device is probably not worth the time - well, unless someone else already has... :-)
Cheers
Old 8th June 2007, 02:38 PM   #17
Thanks for the reply.
My current thinking is to put the signal (130Hz max) to pin-10 of the parallel port (ACK) and monitor with an interrupt (IRQ 7).
With TTL "high" being 2.4v-5v, a 100-ohm resistor and 7.5V Zener should do the trick, no?
It's an OLD laptop, but I'd still rather not fry parallel port.
Doug
Old 8th June 2007, 10:23 PM   #18
It "should" but I'd opine that it isn't the safest solution. If ever the signal goes above 12V, (i.e a transient), you may still zap the parallel port. Also, if the zener were ever to fail (again, perhaps due to a transient), it can fail as a short, and there again goes the port.
I think a resistive divider is safer. Use values to get the 12V down to about 3.5V then add a zener to ground rated at 5.1V to catch any wayward signal that may come around.
Cheers!
12v to ttl converterHide this!Advertise here!
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
24 bit 356 kHz DA converter martioz Digital Source 10 13th December 2004 08:01 AM
NEED DC to DC Converter sma Car Audio 3 16th December 2003 06:24 AM
24v to 12v converter moi Parts 5 15th September 2003 12:47 PM
