diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Everything Else (http://www.diyaudio.com/forums/everything-else/)
-   -   S-video to RCA cable? (http://www.diyaudio.com/forums/everything-else/87034-s-video-rca-cable.html)
coolpoppa 24th September 2006 03:10 AM
Anyone know how to make an s-video to RCA cable? I know you can buy em for like $10, but I've got tonz of cables & a soldering iron, and I've never used an svideo cable for anything. I just want to plug my laptop into my receiver feeding to my projector. I found a few other tuts, but they both mention 4 wires, whereas the svideo cable I just cut open only has 2, a black and a red, both have braided shielding.
AndrewT 24th September 2006 07:30 AM
I do not know for sure, but I think an S-video cable has just video on it.
If this is the case then you need an extra cable to connect the audio.
moamps 24th September 2006 09:39 AM
http://www.epanorama.net/circuits/svideo2cvideo.html
MikeB 24th September 2006 11:15 AM
coolpoppa, are you sure your receiver and/or beamer do not have S-Video connections ?
You don't want a messed up composite signal beamed to big sizes...
S-Video is way above in quality compared to composite.
The adapter shown by moamps will work, but produce heavy color artefacts.
BTW, two shielded wires are in fact 4, the shields are the ground wires.
Mike
coolpoppa 25th September 2006 10:37 PM
Thanks everyone for the replies, I don't have svideo inputs on my current receiver. I figured I could just make a quick S-video to Rca and have it work. So do I take the two wires and twist them toether and use thos for the video sig on the RCA and the grounds to the ground of the RCA?
I guess I would really like to go from VGA to Component if possible. I have a cable that should do this, but for some reason, it doesn't. This is the cable I have:
http://mobyent.com/index.asp?PageAct...OD&ProdID=6864
The only thing I can think is that maybe my drivers aren't working on my laptop. this should put out a signal on either component or composite, correct?
AndrewT 26th September 2006 06:58 AM
are you sure?
Composite has one RCA plug/socket.
Component will have three RCA plugs/sockets (plus audio).
Schaef 26th September 2006 12:44 PM
I'm not sure on wirirng, but the adapter you bought, well, its good for a computer monitor. That ad is one of the most mis-leading things I have ever seen. What it appears to do is simply take the red, green, blue, horizontal sync and vertical sync pins and break them out into RCA connectors. In other words, pointless for most HDTV presentations. The only way I can see that connector will work is if you put your video card into one of the HDTV modes using the exact horizontal and vertical sync timings and then hook up the RGB RCAs to the TV, ignore the H/V sync connectors.
In other words, its doable, they technically didn't lie, but its not very easy, or intuitive.
Copyright 1999-2017 diyAudio
