| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Could capacitors be great antennas?
I have the impression that it is the case. I get a better signal by hooking up a non-polarized electrolytic cap than a bare wire on my tuner's antenna input. (And putting both makes an even stronger signal) All that makes me wonder if audio equipment PSUs could be picking up RFI through the caps...
Antoine http://dmsaudio.ca/ |
#2 |
Could it be the coil component of the electrolytic that is acting as the antenna?
All the trouble I've ever been in started out as fun...... |
#3 |
The antenna connection to your receiver is a super high gain circuit of high impedance, so the microvolts of signal can be amplified. The power supply caps are generally grounded, and they are in very low impedance circuits, and circuits without gain. Even if the inductance of the cap raises the impedance at RF, the wiring and other stuff ought to be better antennae than the caps.
The size and shape of the part might act as a slightly better antenna at the frequencies you are using than the piece of wire, or it could be the wire is actually coupling to something else nearby which dampens its reception. I don't think that the powr supply caps are the source of your RFI. The experiment would be to attach your antenna cap to the power supply just as you did to the antenna terminal and see if there is a noise difference. DOn't forget to keep the covers on the amp for the test. |
| CSC Vitamin Q capacitors good/bad? | jonusgrumby | Parts | 0 | 16th April 2008 03:47 AM |
| Basic RF question about AM/FM antennas | rtarbell | Everything Else | 7 | 31st July 2007 02:08 PM |
| RF question on Am and FM antennas for a stereo | rtarbell | Everything Else | 2 | 2nd July 2007 08:33 AM |
| Apexjr capacitors for gainclones? Which ones are good? | nick_g_evans | Chip Amps | 4 | 14th December 2004 02:27 AM |
| Antennas | eRiCdWoNg | Everything Else | 6 | 11th January 2004 03:17 PM |
| Page generated in 0.09001 seconds (61.14% PHP - 38.86% MySQL) with 10 queries |
