Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 18th September 2006, 10:59 PM   #1
jkeny is offline jkeny  Ireland
Banned
Default Testing polarity of Eltrolytic Cap
I've searched but found nothing here. Can anybody tell me how to test which is the neg pole of an electrolytic cap. I have good electro caps with no jackets.
John
Old 18th September 2006, 11:39 PM   #2
Geek's Avatar
Are they axial? The end with the crimp is usually positive.
Old 19th September 2006, 12:34 AM   #3
Enzo is offline Enzo  United States
And if they are radial with wire leads, the positive wire is often longer. Snap-ins often color code the negative leg black.
Old 19th September 2006, 01:55 AM   #4
poobah is offline poobah  United States
poobah's Avatar
In general, un-labeled might be bad news.
How do you know what the voltage and capacitance ratings are then?
How did they lose their label?
A little history? They may not HAVE a polarity (don't count it).
Backwards caps EXPLODE... really.
Send me a PM.
Old 19th September 2006, 05:55 AM   #5
I_Forgot's Avatar
But they sound so much better without their jackets!
I_F
Old 19th September 2006, 06:20 AM   #6
clem_o is offline clem_o  Philippines
I think this will work:
Set up a DC source, variable output if possibe. Put a resistor in series with the cap, i.e. 1K ohm.
SLOWLY increase the output voltage of the source, while watching the voltage across the resistor. Vr should always be zero. If it begins to rise, you probably have the polarity of the capacitor inverted - remove capacitor, short it, and re-insert the 'correct' way. Retry and confirm that the voltage across the resistor always remains zero.
Any idea what the voltage rating of the capacitor is?
Cheers!
Old 19th September 2006, 07:26 AM   #7
AndrewT is online now AndrewT  Scotland
that last process is similar to a leakage test.
Increase the resistor to 100k and then check the leakage vs the charge voltage.
When the leakage starts to increase suddenly with increased voltage you have probably past the maximum working voltage.
This same leakage increase (but at a much lower voltage) also indicates that you have it the wrong way round.
This will also reform the cap if it has been out of service or used on low voltage duty for a long time.
regards Andrew T.
Old 19th September 2006, 09:19 AM   #8
Banned
Hi all,
Thanks for the replies. I will be using this leakage test to test the viability of these caps
A bit of background - the nude caps are radial Panasonic FC 1,000uF 63V rated which were used before & I inherited them - so legs are already cut. A suggested way is to test continuity between case and lead (the neg lead should give continuity)
4 Pole caps are ROE 10,000uF 40V (X2) & 20,000uF 16V - these have their jackets & there is a vertical line running up the jacket in line with a pin that is marked on top with a (-) - I presume that this is the neg pole. The other pins are marked 1, 2, 3. I believe only one of these is the pos pole the other two are for fixing. How to test for pos pole then?
JOhn
Old 19th September 2006, 03:33 PM   #9
most electrolytics have the case isolated from the capacitor.
You might get a bit of leakage to the case but this should be very small. It may show up as a negative voltage on the case.
regards Andrew T.
Old 19th September 2006, 03:46 PM   #10
poobah's Avatar
If the pins are numbered... just look at the data sheet!
Ess AMT polarity? Help promitheus Planars & Exotics 1 13th July 2007 09:52 PM
Hi-Vi B3N polarity Gollum Multi-Way 5 5th July 2007 05:58 PM
Polarity on OB sub icebear Subwoofers 3 29th April 2005 08:24 AM
LED polarity guitargully Solid State 4 12th January 2004 04:14 AM
Polarity Myren Multi-Way 6 22nd December 2001 01:44 PM
Page generated in 0.11295 seconds (68.49% PHP - 31.51% MySQL) with 10 queries
