| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hello,
I'm interested in building a pair of binaural microphones, and use a dummy head. First, I don't know much about electricity, I just do possible simple stuff from time to time, so talk simple to me, guys. I assume that the weakest part of cheap recorders (MD's or HD recorders) are the preamps. So, it's logical to push the mics to line level, and adjust the proper output impedance. Many recorders have line input but not all of them got line input. Looking at Linkwitz's design (is this guy thrustworthy or what?) : http://www.linkwitzlab.com/sys_test.htm#Mic Do you guys think that it's a good base for a stereo schematic? How should this simple preamp compare to the ones found in sub $400 recorders? (and even the new Sony Hi-MD's?) If so, what will happen if I share these batteries with the second mic? What should I change in this schematic if I want to add the second mic? There's also Rod Elliot's version (look at the one with the preamp): http://sound.westhost.com/project112.htm I don't have the slightest idea what would be better (-: By the way, where's a good place to buy these Panasonics that also has a large selection of electronic parts? (Like Mouser, bt they don't have them) Thanks Adam |
#2 |
hi
I have a couple of National Panasonic WM-034 at home. Very good electret microphones in relation to low price! WM-61A is even better, and to prefer, what they say. But I took what could find. At this panasonic page you can download PDF Datasheets for your microphone WM-61 http://www.panasonic.com/industrial/...io/aud_mic.htm Yours: http://www.panasonic.com/industrial/...61_a_b_dne.pdf Here is mine, WM-034: http://www.panasonic.com/industrial/...db_c_d_dne.pdf WM-61 ![]() WM-034 ![]() lineup the microphone amplifier builder
lineup |
#3 |
Linkwitz and Elliot are extremely respectable and anything on their sites is well thought out.
The mod on the pana mic is necessary but may be a little bit tricky if you have no soldering experience.They mikes are very cheap and you can buy a dozen if you can find some in small quantities to experiment.A preamp may not be necessary depending on recording levels and gain of MD.Otherwise quality can be very very good although personally I found that playing thru speakers needs some bass eq cut. Ideally you should try and match the two stereo mikes for close output levels so getting some extra mikes is always a good idea.
``The author always assumes that when power is applied , the amplifier will explode or ,at the very least, catch fire.´´ Morgan Jones, Building Valve Amplifiers. |
#4 |
Linkwitz site also has a design with the mics on a pair of eye glasses.
Hear the real thing! |
#5 | |
IIRC, the optimal ratio between output and input impedance is about 1/10. Is that correct? Thanks! |
#6 |
I used an INA217 with the WM-61. It's just based on the datasheet at www.ti.com. Simplest solution for best performance. I can change the gain by plugging in different resistors into a DIP socket.
#7 | |
( This is a replacement of much used and good SM2017 mic amp IC ) Here a very nice project using this INA217 ( SM2017 ) with 2 High quality LM833 OP-amps for the output. Included many schematics and pictures! KDMP - Kev's Dual Mic Pre in a rack box http://www.celestial.com.au/~rosswood/diy/KDMP/kdmp.htm lineup microphone web search service
lineup |
#8 | ||
Well, I've decided that my player with be the Sony MZ-NH600.
It's a HI-MD player that works on AA. Only line ins. However, I don't know if it's possible (or easy) to change recording levels from it on the fly. I want the rig to be very portable, So it's either Elliot or Linkwitz's design. As the discussed circuits are all quite small, quality is the first thing to consider. OTOH, I hope I won't have to carry more then 2 9V batteries in this pack (and get reasonable battery life). But I still didn't get a straight answer from anyone about what input level and impedance should the line in section in the MD player "see" , considering that it's the modded capsule used. Linkwitz staits the specs of the WM-61A's capsule and his circuit but honestly I don't really understand it, translate it to my needs, and choose one of his circuits, or maybe Rod's. Let's reorder things: Linkwitz's single channel 10dB preamp version (/w WM-60AY) ![]() Quote:
#9 |
One Sony MD that I have used before, I did not even need a preamp or battery. It supplied aournd 2.5V phanton power. All I had to do was hook the panasonic capsules into the MD using a 3.5mm earphone plug. I actually moded a set of earphones and used that. The MD I used allow changing volume level on the fly. One thing though is that the recording was polarity inverted. For best results, it needs to be inverted back during playback.
#10 | |
hi
Linkwitz used WM-60A in his first set up, as seen in his schematics with modified elektret input-JFET mic transistor circuit. As told by previous poster here WM-61A can be used to replace with improved performance. somewhat higher sound sensitivity and lower noise ----------------------------------------------------------------------------- For those in northern Europe, who would want to try the very good (performance/price) Mic capsule Panasonic WM-61A .... we have a supplier here ![]() Quote:
Prices: (I think maybe you can find lower price at some bigger electronics suppliers) For delivery inside EU 1-4 pcs WM-61A EUR 6.94 5-9 pcs WM-61A EUR 5.76 10+ pcsWM-61A EUR 4.59 StartPage http://www.svalanderaudio.com/ Some good stuff for Vinyl Turntables .. like extremely good Cartridges Nagaoka ! Ortofon etc. and other fancy Vinyl Accessoires. VinylPage-Shop: http://www.svalanderaudio.com/vinyl/vinyleng.php lineup - North Europe
lineup |
| First post and need help: Creating Binaural Mic! | Prismatic | Everything Else | 5 | 31st July 2010 02:37 PM |
| Binaural recording of 4th of July fireworks | zapnspark | Everything Else | 34 | 8th July 2008 10:31 PM |
| Binaural recording: alternatives to expensive dummy heads? | KT | Everything Else | 11 | 7th September 2006 09:30 PM |
| Stereo to binaural and crosstalk cancellation | Nixie | Digital Source | 0 | 8th February 2006 12:34 PM |
| WTB: Binaural Recordings | drewm1980 | Swap Meet | 0 | 9th August 2005 09:55 PM |
| Page generated in 0.12913 seconds (88.54% PHP - 11.46% MySQL) with 10 queries |
