Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 16th September 2006, 11:34 PM   #1
Default pcb mounting
i'm wondering what everyone else are doing to mount pcbs inside metal boxes? i don't want to drill the bottom to run screws through it. any other ideas?
Old 17th September 2006, 02:54 AM   #2
Geek's Avatar
In that case, I use rails to mount the PCB that also hold the faceplate and rear panel in place (common method with Hammond cases) or make a sub chassis so there are only 4 mounting screws or rivets visible.
Old 18th September 2006, 02:08 AM   #3
aerius is offline aerius  Canada
For one of my projects (a small headphone amp) I glued a few small plastic stand-offs to the PCB to keep it from contacting the metal box, then flooded the entire box with wax.
For larger projects, try gluing a piece of wood to the inside of the metal box and then screwing the PCB into the wood.
Old 18th September 2006, 02:36 AM   #4
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
You can always just glue the standoffs to the inside of the case. A wooden or metal sub-chassis (as was already mentioned) is also a good method that will allow you reuse the case in case you ever plan on using it for another project.
Brian
what is the mounting depth and mounting diameter of this? lemans23 Multi-Way 2 26th October 2005 11:52 PM
Hi-vi B3s mounting kenp3 Full Range 6 18th October 2005 04:33 AM
PCB mounting pjanda1 Chip Amps 1 3rd May 2005 10:31 PM
Mounting TO-3s Devil_H@ck Parts 7 30th March 2004 09:19 PM
Page generated in 0.06756 seconds (70.49% PHP - 29.51% MySQL) with 10 queries
