| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#21 | |
diyAudio Moderator Emeritus
Here is the schematic for the pic board that I am using (page 6): http://www.picbook.com/%7Epbpdf001/bookinfo/CA1.pdf It is from a class here at georgia tech. More details at: www.picbook.com You can actually purchase pcbs and a parts kit from digikey: 18F452-KIT-ND if you are interested in making your own pic development board. The whole thing could be obtained for about $120 including the book. -- Brian |
#22 | |
#23 |
Yes, i see the regulator on the schematic so it will be on the PCB I guess.
Another question Brian. Should we tie both grounds? I mean the PIC board ground to the star ground of the preamp? Or this will contaminate the ground of the preamp? |
#24 | |
What is a good plan for a regulated 5v power supply? It doesn't seem to be too important, as it only powers the control logic. As for an earlier comment about the vfds making a lot of noise, if you look at the Passlabs amplifiers, all of the expensive ones have the vfd in the same chassis as the analog circuit, so it can't be that bad: -- Brian |
#25 |
Good pic Brian, never saw that before. Its the Aleph P 1.7?
I think a good alternative for a reg PSU would be a similar to the one used by Nelson on preamps (and even Zen amp), series FET with a zener reference, but I don't know if the voltage is to low for this arangement. |
#26 | |
http://www.passlabs.com/prodlit/x1lit.htm The power supply doesn't need to be overly complex, since it is jus for control logic. -- Brian |
#27 |
Brian,
You mentioned that it's a passive volume controller and it appears that it's connected to the line out. Do I have to remove the two 2 gang pots that I have already installed on my BOSOZ? I know it sounds elementary but I'm asking anyway. |
#28 | |
-- Brian |
#29 |
BrianGT, not too related, but why did your class choose to use a MAX232A verses a MAX233(A)?
#30 |
o.k. then, I'll be looking forward to your completed design.
| relay volume control | cubezone | Chip Amps | 14 | 3rd May 2007 07:12 AM |
| relay volume control - POP! | wayne325 | Pass Labs | 22 | 26th August 2006 01:58 AM |
| ADC for relay volume control? | hegestratos | Solid State | 7 | 17th January 2005 11:39 PM |
| Relay Volume Control for BLS | promitheus | Pass Labs | 60 | 10th May 2004 06:12 AM |
| Page generated in 0.11199 seconds (81.28% PHP - 18.72% MySQL) with 11 queries |
