Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 1st March 2003, 01:27 AM   #111
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
Jordan, I took a look at ftorres' cascaded ladder attenuator design. I agree that his has superior usable range, but it also uses twice as many relays! After reading his article, I don't buy his logic about not doing the make-before-break when the LSB does 000->111 or 111->000. Unless my calculations are wrong (again), I think you can engage, for example, -70dB and -60dB dividers simultaneously to produce a -66.7dB divider of 25.0KΩ and 11.5Ω. You can also engage the 0dB and 8.75dB dividers to produce 0dB (duh). So, if you are going from -70dB to -68.75dB you stop by -66.7dB on the way there. Not too bad of a jump, I don't think.
Similarly going from -20dB to -18.75dB takes a stop at -25dB. Not too bad of a bobble. Certainly it isn't as bad as if you just let the relays flop, in which case you would go to mute between each setting.
The actual problem comes in when you are going from -10dB to -8.75dB. In this case you make a stop by -0dB on the way! This could be avoided by using separate latches for each bank of relays, and controlling their timing separately.
Finally I noticed that the -10dB divider seems wrong. It should be 34KΩ and 16KΩ, not 60.4KΩ as marked in ftorres' drawing.
relay volume control cubezone Chip Amps 14 3rd May 2007 07:12 AM
relay volume control - POP! wayne325 Pass Labs 22 26th August 2006 01:58 AM
ADC for relay volume control? hegestratos Solid State 7 17th January 2005 11:39 PM
Relay Volume Control for BLS promitheus Pass Labs 60 10th May 2004 06:12 AM
Page generated in 0.10457 seconds (48.20% PHP - 51.80% MySQL) with 11 queries
