Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
What should I use for a crossover?
Old 5th September 2006, 06:42 AM   #1
punkrokr1701 is offline punkrokr1701  United States
punkrokr1701's Avatar
Send a message via AIM to punkrokr1701 Send a message via MSN to punkrokr1701 Send a message via Yahoo to punkrokr1701
Question What should I use for a crossover?
I've posted something related to this in the electronics and parts forum earlier.
Anyway, I'm building a set of cabinets and I need a crossover that can handle a current of 1550 watts rms at 8 ohms.
Here's all the info that I have on the speakers:
12 inch Woofer:
*Power handling: 300 watts RMS/600 watts max *VCdia: 3" *Le: 1.33 mH *Nominal impedance: 8 ohms *Re: 6.0 ohms *Frequency response: 50-4,000 Hz *Magnet weight: 71 oz. *Fs: 42 Hz *SPL: 96 dB 1W/1m *Vas: 3.81 cu. ft. *Qms: 16.33 *Qes: .32 *Qts: .31 *Xmax: 3.5 mm *Dimensions: Overall Diameter: 12-1/8", Cutout Diameter: 11", Mounting Depth: 5-1/8".
6 inch Mid bass:
*Power handling: 100 watts RMS/200 watts max *VCdia: 1.25" *Le: 0.57 mH *Nominal impedance: 8 ohms *Re: 5.9 ohms *Frequency response: 80-9,000 Hz *Magnet weight: 19.8 oz. *Fs: 76 Hz *SPL: 91 dB 1W/1m *Vas: 0.28 cu. ft. *Qms: 6.7 *Qes: 0.95 *Qts: 0.83 *Xmax: 2.3 mm *Dimensions: A: 6.54", B: 5.63", C: 2.9".
Tweeter:
3 " ALUMINUM BULLET HORN WITH 1" SUPER TWEETER 40 OZ MAGNET STRUCTURE 250/500 WATT PEAK POWER FERRO FLUID ENHANCED FREQUENCY RESPONSE: 2k-25 KHZ SENSITIVITY: 99db IMPEDANCE: 4-8
And yes if you do the math that means there's two woofers, two mib bass drivers, and three tweeters.
Please don't criticize my design, I've already built a smaller version of the same set up with 8 inch woofers, 4 inch mid ranges and 1 inch dome tweeters. It sounds great but now that I've got a bigger living room I need more power so that's why I'm building a bigger version of my current speakers.
The crossover I used for my smaller speakers was a Dayton crossover from parts express that handeled 300 watts.
I can't find anything that will handle 1500 watt rms.
So I was wondering if I could install a Dj crossover on the speaker cabinets and if I could, how should I wire it up?
And if that's a ridiculous idea then what would I need to build my own crossover and where can I get the parts?
Old 10th September 2006, 07:27 PM   #2
chrispenycate is offline chrispenycate  United Kingdom
chrispenycate's Avatar
Have you bought the power amp yet? Silly as it might seem, it might be easier to use an electronic crossover and multiple power amps at this sort of power, and not nescessarily that much more expensive. This enables you to match speaker sensitivities without losing damping factor, (I don't know those bullet tweeters, but I'll make a small bet they'll sound better off a very low impedance) While high power passive crossovers are available for PA systems, they tend to be designed for particular sets of speakers, generally from one manufacturer.
Do you need the multiple tweeters for coverage? They are a bit directive, and I can't think of any style of music that would need that much power in the ultra highs to match that little power at the low end (in one PA system we've got 100 watts of JBL bullet matching 2000 watts of bass and mid, with 15" low end drivers (I don't actually have the sensitivities at my fingertips) which should be at least as efficient as 12", and horn loaded mids.
9 and eve
What should I use for a crossover?Hide this!Advertise here!
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
Help me with a crossover. raypalmer Multi-Way 4 5th April 2009 01:48 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Crossover help please :) Tenson Multi-Way 17 15th April 2006 09:34 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Copyright ©1999-2017 diyAudio
