| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#11 |
BAD boy...
#12 | |
Hi Poobah,
Cheap IEC's http://www.cascadesurplus.com/catalo...products_id/53 |
#13 |
Not only do I have the correct Qmax cutter for IEC sockets (proving that it has at one time existed, even if it's now unfindable) but one for Bulgin mains sockets. Prices for these punches have soared, haven't they?
#14 | |
diyAudio Moderator Emeritus
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#15 |
Most of the IEC sockets I have come across require a minimum cutout of 19mm x 27mm. Square sheet metal punches are easy to find, so if you found a 19mm or 3/4" punch you could just punch a square with it then use a file or nibbler to remove another 8mm of material.
I've looked and looked for an IEC punch in the past and had no luck finding one. I do it the dangerous messy way of using a cut-off disk and a dremel tool. When a cut-off disk explodes at 30,000rpm you better hope your face isn't in the way of the shrapnel.
#16 |
1, that's how I do it. A few drilled pilot holes and a cutoff disc. The cheap rectangular IEC sockets have enough of a flange to cover up the less-than-perfect edge.
The Dremel is the single handiest tool for electronics construction that I know.
If there's a sucker born every minute, where do the rest of them come from? |
#17 |
Since I only use aluminum or brass for chassis, I just use my scrollsaw with a 28TPI twist blade and lotsa oil.
Not nearly as much fun as a punch, but it gets the job done Just remember to bend the chassis *after* making the cut (more experience) |
#18 | ||
I use composite type cut-off wheels. They are built up on a fiberglass disc so they don't shatter and explode like the cheapy all-stone ones that come with the dremel tool. I bought a 5 pack for about $10. It was the best $10 I've spent since I bought the dremel tool. Cut off wheels are great for cutting bicycle brake and shifter cables and their jackets. I wrap the cable with a piece of tape, then cut the cable mid way through the tape. The tape keeps the cable from fraying while cutting. I hear that car thieves defeat "the club" type steering wheel locks by using battery operated cutoff saws to saw through the thin steel at the core of the steering wheel rather than the thick steel of the lock... I_F |
#19 | |
#20 | |
I learned very quickly to keep my face out of a broken disks flight path. I had one explode and take some skin off my cheek right below my eye, another inch up and I hate to think of what would of happened. |
| Rons Austin A126 for the metric freak newbie | FlorianO | Full Range | 136 | 26th November 2010 04:55 PM |
| Relapse audio freak joining. | jbop | Introductions | 2 | 4th April 2007 11:39 AM |
| Any high end freak from france? | till | Everything Else | 3 | 3rd October 2002 12:31 PM |
| Page generated in 0.14660 seconds (100.00% PHP - 0% MySQL) with 9 queries |
