Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
I am an IEC Socket Freak
Old 5th September 2006, 11:50 PM   #21
Geek is offline Geek
Geek's Avatar
Originally posted by EC8010
Methylated spirits (that purple stuff) is much better than oil. I haven't looked back since finding that tip in Deketh.
Thanks EC!
Old 7th September 2006, 12:20 AM   #22
bulgin is offline bulgin  South Africa
Default I am an IEC Socket Freak
Thanks Guys!!!
A square punch it'll be. Instead of Dremel, I use the Other tool - Proxxon. They also have some great accessories. The motor is permanently on my workbench, mounted in Proxxon's suction vise - staying firmly in place for months on end. This brand's best cutting discs are diamond-coated cutting and grinding wheels.
The only criticism I have is that their mandrels are too thin and usually snaps the screw which holds whatever disc you have on it.
A peculiarity with the Proxxon motor tool I experienced was doing a nutsplitting job on a lawnmower, done outside to see better. I fitted a diamond cutting disc in the tool and used an unwound cable drum mains lead of 30m long. After about 2mins worth of cutting, the tool got very hot and I could smell overheating electronics.
As the job was done, I decided to dismantle the tool to check for damage. There was no sign of overheated electronics and everything was OK.
Since the tool's speed control is by electronics up to 20k rpm, the extension cable I used must have had some effect, causing overheating.
So, if you use one of these, don't use it powered by a long extension lead.
bulgin
Old 7th September 2006, 03:16 AM   #23
I_Forgot is offline I_Forgot  United States
I_Forgot's Avatar
The smell was probably either the bolt you were cutting or the cutting disc, or both.
If you're snapping screws on the mandrel, you're applying too much pressure and you're going to bust the disc.
I_F
Old 8th September 2006, 11:59 PM   #24
mobyd is offline mobyd  New Zealand
mobyd's Avatar
I use one of these...
When all the little sheetmetal places were either going
CNC or being knocked down and turned into coffee shops
flypresses could be had for scrap value. They do whatever
shaped hole you care to buy punches for. A 20mm square
punch does an IEC in 2 swats.
M
Old 9th September 2006, 12:02 AM   #25
poobah is offline poobah  United States
poobah's Avatar
That thing would work great just for smashing things!
Old 11th September 2006, 06:45 AM   #26
XEAGLEKEEPER is offline XEAGLEKEEPER  United States
XEAGLEKEEPER's Avatar
I used a bridgeport mill with a .250 in. end mill. Then dress the 90 degree corners with hack saw blade and a small file.
Old 11th September 2006, 07:14 AM   #27
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
A quick google search found this. Not novel, but a good collection of methods: http://www.makezine.com/extras/15.html
I am an IEC Socket FreakHide this!Advertise here!
Rons Austin A126 for the metric freak newbie FlorianO Full Range 136 26th November 2010 04:55 PM
Relapse audio freak joining. jbop Introductions 2 4th April 2007 11:39 AM
Any high end freak from france? till Everything Else 3 3rd October 2002 12:31 PM
Copyright ©1999-2017 diyAudio
