| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hi all,
I'm noob in electronics but want to try DIY a simple Vol. Control I want to make a very simple volume control between my DAC and Active Cross-Over Unit. From the MultiMeter Reading, my DAC RCA output jacks have 10K Ohm (also claimed to have 2.5V output) The destination RCA input jacks of Active Cross-Over Unit have 7K Ohm (reading from multimeter) I tried to diy a simple POT with IN OUT RCA Jacks (tried 1K, 10K, 20K, 50K, 100K) I got a active preamp for test of volume before I plug the diy POT between in order to avoid sudden burst out of volume. "Safe" test path: DAC > diy POT > active preamp > Active XO Test path : DAC > diy POT > Active XO Regardless of (value of K of the POT,), the sound level will suddenly increase hugely. Simply cannot rotate the POT's 1/10. I have difficulty to archieve the suitable volume level. ![]() Appreciate for advices. |
#2 |
What taper pots are you using?
sounds like you're using linear taper, for volume control you need Log taper. Regards, Pete McK |
#3 |
Check out this page for an explanation,
and how you can change one of the pots you already have to log taper with a couple of resistors: http://sound.westhost.com/pots.htm#chg-law |
#4 |
sounds more like you have not connected the grounds to the pot lower leg. |
#5 | ||
Thanks You guys. The attached link really helped me that I finally know a POT with connection and grounding could have different functions! As a noob in electronics, simple thing like above already giving me big trouble!
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| The remote control paratactic volume control | audio-gd | Solid State | 33 | 7th June 2007 11:16 PM |
| 5.1 volume control | Dan2 | Chip Amps | 3 | 19th November 2006 01:35 PM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 11:12 AM |
