diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Everything Else (http://www.diyaudio.com/forums/everything-else/)
-   -   Samples (http://www.diyaudio.com/forums/everything-else/85608-samples.html)
jkeny 30th August 2006 12:53 PM
Samples
I registered with Philips & STMicroelectronics yesterday but can't find any where to order samples.
Do these IC Manus have sample programs? Can anybody direct me to the relevant site area?
John
AudioFreak 30th August 2006 01:41 PM
Perhaps pointing out the obvious but sample programs are for engineers to test a design before going into full scale commercial production. If this is not your intention then you'd be well advised to source your devices thru the retail stream. Abuse of sample programs ultimately hurts everyone.
morpheus82 30th August 2006 02:38 PM
philips and stm will give you samples if you contact them and only after explaining them you are an engineer and you're going to build a project in large scale that will use thousands of chips that you'll pay one day...and this is not your case...nor mine...:D :bawling: :smash:
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
