Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
need list of "standard" values such as impedance
Old 29th August 2006, 02:32 AM   #1
keantoken is offline keantoken  United States
keantoken's Avatar
Default need list of "standard" values such as impedance
I need a list of the "standard" values such as impedance for a phono RCA jack output and standard voltages for such. The reason is that when I build my own amp, I want to implement phono and video inputs/outputs and such. If you have any hi-fi impedance matching circuits please post them! The main amp I want to build is symasm4, which is the best one I know of. If you know of a better amp with around the same component count, please post! Thanks in advance .
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 30th August 2006, 03:26 AM   #2
keantoken's Avatar
!!!???no poste'? Come on guys... I at least want a good RIAA network...
Old 30th August 2006, 04:59 AM   #3
I_Forgot is offline I_Forgot  United States
I_Forgot's Avatar
Output levels vary depending on the manufacturer of the audio component in question. One thing that is nearly universal is that "line-level" outputs are low impedance (typically less than 200 Ohms or so) and line-level inputs are almost always >10K ohms.
Since you are building the preamp/switcher yourself, the best thing to do is measure the output levels of the components in question. CD players are easiest, because you can pop in a test CD (and you can make that yourself) with a 60 Hz, 0dB sine wave and read the maximum output with any multimeter.
Tuners, TVs, etc. may not be so easy but it isn't going to be critical anyway. Most multimeters aren't any good at measuring AC voltages that aren't sine waves, so your best bet is to use an oscilloscope. If you don't have a scope, then just assume the output levels are about the same as the CD player and leave it at that. You can always change amplifier gain later by swapping out a feedback resistor or padding the input.
If you want to get fancy, you can use a uC to make an adjustable attenuator and switch inputs, and make it programmable so you can match the levels depending on which input is selected. That sort of thing takes some pretty simple software.
I_F
Old 30th August 2006, 05:40 AM   #4
keantoken's Avatar
Well, that clears all that up (somewhat). Thanks.
need list of "standard" values such as impedanceHide this!Advertise here!
Using a standard pentode-tetrode as output "space-charge tube" any ideas-experiences? bembel Tubes / Valves 12 11th March 2010 06:56 AM
"A standard CD player outputs signal at 24V" wwenze Digital Source 16 13th July 2009 05:50 PM
cheap 6" or 8" woofer to make great bass for a standard cab pick up zuki Subwoofers 12 15th February 2005 08:54 AM
A "Standard Noise Source" for SPL meters. Jonathan Bright Everything Else 6 13th July 2004 11:19 PM
"Standard" EIC power input vs. Filtered EIC Eric Everything Else 16 18th May 2001 10:31 AM
