| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Anyone know of any companies that build (either custom or pre-fab) 3-way Low/Mid/High (4 ohm) passive crossovers for a PA speaker setup? Everyone makes the 8 ohm sets which is what I've been using, but I'm in a position where I can afford to replace them with the proper x/o's.
I've thought about picking up a set of matched Eminence 500 Hz / 3.5 kHz crossovers (8 ohm) and converting them to 4 ohm, but I'm not sure how much work that would take. I'm not building high quality speakers here also.. these are simply smaller bar/house party dj speakers. Lets keep the budget around $150.00 for the set. |
#2 |
I take it you don't solder?
Since you're looking at using a store bought 3-way that may or may not match the curves of your speakers, I bet you could build your own within the price range stated if you soldered or knew someone who did. The Eminence xo's use -12db for bass, a -6db for midrange and a -18db for the tweeter slopes in thier Parts Express xo's. Using a few of the online calculators you could make something similar yourself. I think you'll notice that in order to convert from 8ohm to 4ohm values, you basically cut the existing values in half. R Jim |
#3 | |
| Passive crossover into active crossover | hahfran | Multi-Way | 16 | 10th February 2008 06:16 PM |
| Passive Crossover for Passive Subwoofer? | Toast_Master | Subwoofers | 23 | 30th April 2006 12:14 AM |
| Crossover passive components | Madmike2 | Multi-Way | 1 | 17th June 2005 05:18 AM |
| Passive crossover | Twisted | Parts | 0 | 19th January 2004 08:32 PM |
| About passive crossover | stefanobilliani | Pass Labs | 5 | 2nd August 2002 07:39 PM |
| Page generated in 0.08347 seconds (80.15% PHP - 19.85% MySQL) with 10 queries |
