| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#31 |
diyAudio Moderator Emeritus
Tell that to the world (see post #20). Often is chosen for the cheapest solution by commercial operating power companies. Here (national anthem sounding in the background) the choice was made for a simply good solution in the past .... That is why I do not object against a government ruled power company that provides energy at cost without the need to make profits, give out stocks and pay high salaries to too many managers etc. A plain old fashioned government owned power company will provide labour for many and it will ensure timely maintenance and/or replacement of older cabling etc. Something that is not so sure with commercially driven companies with names changing faster than my eyes can winkle.
Not having hurricanes and tornados in this part of the world helps somewhat too.
It's only audio Last edited by jean-paul; 25th July 2010 at 11:19 PM. |
#32 |
Brain, thanks. Completely agree with your post #26. I was not precise with the terms.
J-P. Yeah, I was fond of the EDF (and SNCF) too.
Take the Speaker Voltage Test! |
#33 |
hey, I consulted my buddy
his magic word was spike killers or transient killers specialised for mounting directly onto the main security board he says the spikes is where the noise is "hiding" insanely expencive small bastards and he even talked about having 3 more in front of that he also showed me different kinds of spike killers fore just about every incoming cable, from ordinary antenna and telephones to digital signals and yeah, as mentioned previously, adaptors seems the schuko plugs actually have a special "adapter hole", which matches the third pin with earthing on our local plugs and if I want even better earthing/ground, another possibility is to use multiple earth/ground spears, about 6meters apart, all connected together I might end up in a heavily shielded farraday cage ![]() |
#34 |
On of the cheepest and easiest ways of stopping conducted noise at RF is to put a ferrite round your mains cables, if they havn't already got one. Its worth a try as they are so cheap.
#35 | |
yes, I have mains wire to PC wrapped around a toroid, and it helps
Its just not good enough a PC needs the earth leg connection, as pr Jean Pauls post around here its usually the switchmode smps that goes first in a PC, and takes out the whole computer I do have connectors with earth in the renovated area of my house but many older installations were made before computers everything was double isolated, thus only 2leg connectors only washing rooms had earth connections only newer installations are prepared for this new world hey, I just figured how to get better sound buy a ton of cheap earth leg adaptors, and hand them out free to every one who passes by I need to check my neighbours ![]() Quote:
| Wich Suppression Capacitor to block Mains emi? | samsagaz | Solid State | 26 | 13th November 2010 10:53 AM |
| Low Frequency Mains Noise | ruffrecords | Tubes / Valves | 6 | 31st October 2008 07:26 PM |
| Noise suppression bypass caps on Si bridge | Steerpike | Power Supplies | 2 | 23rd July 2008 09:33 PM |
| newbie - Kenwood 3020SE mains noise? | jimh0612 | Solid State | 19 | 25th April 2007 01:49 AM |
| LM3886 very prone to mains noise | Andypairo | Chip Amps | 26 | 14th April 2005 02:51 PM |
| Page generated in 0.10564 seconds (71.56% PHP - 28.44% MySQL) with 11 queries |
