Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 14th August 2006, 06:47 PM   #1
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
Default Low frequency absorbtion techniques
I would like to ask about low-frequency sound absorbtion in a small room. The stone wool , placed on walls and ceiling does not work in this range. So i am considering to try a helmholtz resonator. However , i have difficulties finding some information on the web.
The room is 6.5 x 3.2 x 2.2 m dimensions , which is not good for sound recording.Very low frequency ringing lasts for seconds if you beat a door with something. It is also seems that there are not many(maybe 2 or 3 ) frequencies , at which the resonances are very irritating.They are probably in the range of 25-100 Hz.
Has anybody had this problem ? What do you think about helmholtz absorber ?
Lukas.
Old 15th August 2006, 04:01 AM   #2
KBK is offline KBK  Canada
Helmholtz resonators will work, you will have to make an array of them at the one end of the room, and make each slightly tunable, to get the best level of absorption, across the widest band. You can chase after the fundamental with just one, but that's always tricky. The energies wil continue to build on the areas where there are none. This technique has been used in some studios, but it takes time and persistence to get it right.
It also sounds like it is a rigidity problem of the walls or floor.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
"Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti
Old 15th August 2006, 08:59 AM   #3
You are right , one wall is made of only one layer of brick, and seems to resonate at specific frequency, as well as concrete ceiling.We have tried putting various layers of damping , but it helped little. It is even possible that wall's resonant frequency is close to room mode resonance , which would make the things even worse.
By the way , how large the helmholtz absorber's volume should be it to be effective ? Is it possible to use 20 cm(8") diameter PVC pipe for enclosure ? What is the best to use for port/volume wadding ?
Lukas.
Old 15th August 2006, 12:35 PM   #4
ralphs99's Avatar
Hi Bazukaz,
Here's an excellent link to resonant absorbers of all types.
http://www.mhsoft.nl/Helmholtzabsorber.asp
Cheers, Ralph
Aeronet research pages
Acoustic, Electronic & Speaker Design
Old 15th August 2006, 01:58 PM   #5
what you will be doing, if you do this thing, is building a bunch of pipes of either 1/2 or 1/4 wavelength of the resonant modes. Full size damped pipes, in size, like those of a pipe organ.
One simple way to check, is to 'pound' (by hand, or rubber hammer) the suspected wall and cieling, in their most flexable point. This is generally in the center of the panel.
If it is all hard surfces, it could even be ventalation systems that are causing this issue. Finding the souce of your woes is the first step. Neutralizing it becomes far easier at that point, as you have an actual target for your efforts. right now, you are in a world of unknowns, so the problem seems far more difficult than it actually is.
Think of the room as a speaker cabinet with serious problems,and the door as the driver mounting point. Then fix the panel and box leakage issues, as well as going after internal damping to kill cross reflections.
Same issues, it is merely a larger scale.
Old 15th August 2006, 08:45 PM   #6
Thanks for your help.
Actually , we are sure that the brick wall resonates. I pound at various places to it , and the low-frequency sound can be heard easily. For sure , the best solution would be to lay another layer of brick , and fill the gap with sand , but i am seeking for a simpler solution , if possible.
Best regards,
Lukas.
Old 15th August 2006, 09:23 PM   #7
If the wall is external, the brace it with a 45 degree angle piece of wood, anchored into the ground.
Old 20th August 2006, 10:13 PM   #8
tarcuper's Avatar
you can use tube traps, wich are effective low frequency absorbers in the range of 30-150Hz. You must put them in the corners behind the speakers, two pieces superposing. Ther are diy tube projects, wich are useful
www.teresaudio.com/haven/traps/traps.html
http://www.dougploss.com/tubetrap.htm
Old 22nd August 2006, 05:30 AM   #9
TwoSpoons's Avatar
Smack the brick wall a bit harder and put some cracks in it. That should help with the wall resonance.
I'm being serious here!
Old 22nd August 2006, 07:44 PM   #10
tarcuper's Avatar
maybe 5% higher or lower the resonance, and the high frequency reflections less above 8 kHz, but nothing seriously may happen.
But there are big differences between men's sensibility...
Useful tools and techniques Peter Daniel Equipment & Tools 327 31st August 2009 07:49 PM
Woodworking techniques johngalt47 Multi-Way 33 11th March 2009 07:07 AM
Frequency CUT and a HOLE in frequency range... -_nando-_ Everything Else 0 28th December 2005 08:17 PM
Techniques SL-230 rewire justn Analogue Source 5 1st October 2005 06:36 AM
Page generated in 0.11865 seconds (73.98% PHP - 26.02% MySQL) with 11 queries
