Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 1st August 2006, 03:06 PM   #1
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Default electronic adjustable resistor
Does any one have this kind of resistor?
For testing supplys,amps,...
Old 1st August 2006, 03:12 PM   #2
mrshow4u's Avatar
I'm not sure what you need. These might not deal with reverse polarities, ....I didn't check'm out. <http://www.home.agilent.com/cgi-bin/...OUNTRY_CODE=US>
".........These go to eleven"
Old 1st August 2006, 03:21 PM   #3
luka's Avatar
Yes like that, but I would like to build one myself,but I dont know where to start, and I don't have any schema for now.
Old 1st August 2006, 03:24 PM   #4
mrshow4u's Avatar
You could parallel up a bunch of MOSFET's and bias the gates up to make an adjustable power resistor. I've never tried that, but in concept it works. It sounds interesting
Old 1st August 2006, 03:29 PM   #5
luka's Avatar
That's what I thougt, but gate drive must be somewhat complicated, because it has to keep the resistance the same, independeble of voltage applyed to mosfer's.
Old 1st August 2006, 03:34 PM   #6
mrshow4u's Avatar
.. Yes, that's where the "fun" would come in. You'd have to monitor the summed currents, measure the voltage across the MOSFETS, then adjust the Vgs to mantain the load resistance.
Old 1st August 2006, 03:36 PM   #7
luka's Avatar
Now how to do that...
Old 1st August 2006, 03:46 PM   #8
luka's Avatar
It would be great to have adj. max current to.
Old 1st August 2006, 04:10 PM   #9
luka's Avatar
Uuu and max power limit.
http://www.elektor-electronics.co.uk...d=28&art=50616
Old 1st August 2006, 04:42 PM   #10
jackinnj's Avatar
We have a great company in NJ -- Transistor Devices -- which makes electronic loads -- they have units which will dissipate 120kW !!! Very often you will see their units for sale on EBay or at Hamfests:
bias supply question / sanity check - adjustable resistor? ilted Planars & Exotics 0 5th May 2009 02:12 PM
Can someone tell me what this adjustable pot is for ? WBFAir Subwoofers 4 31st March 2007 02:32 AM
electronic crossover cap resistor ratio ostie01 Multi-Way 9 17th February 2006 12:57 PM
adjustable resistor or potentiometer choise to use in a crossover maya1 Multi-Way 1 2nd May 2004 02:41 PM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Page generated in 0.11232 seconds (71.93% PHP - 28.07% MySQL) with 11 queries
