Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
bi-wiring problem - explain?
Old 17th July 2006, 08:12 PM   #1
mantisory is offline mantisory
Default bi-wiring problem - explain?
Hi all,
Well, here goes. I have a system which has bi-wired slate speaker cables. Anyway, i noticed that my amplifier's left channel was getting overly warm (to the point of sometimes shutting down). I also blew up the same channel on my gainclone.
Now, looking at my speaker cables i noticed that one wire (of the pair) of the bass' negative terminal had become disconnected from the connector. I soldered it back up, and, lo and behold everything is now fine.
Is the fact that one wire was disconnected enough to cause this behaviour, and if so, why?
Thanks,
Byron
Old 17th July 2006, 08:28 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Can't see how, should just have made no sound from that drive unit. You have removed the bi-wire links between drive units haven't you?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 17th July 2006, 08:31 PM   #3
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
It may have been a dodgy contact, enough to let power through, but loose enough to arc or pose a high resistance causing the heating. This arcing could also be the reason for your your amp problems.
:edit: as could Richie's suggestion about the link.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 17th July 2006, 08:39 PM   #4
actually, the slate cable has a shielded pair per pole, so for each speaker there are 8 wires...
so it would have been that 1 wire was connected whilst its partner was not...but i never thought of the arc'ing problem...although when i discovered it i think the voltage would have had to have been really high to force the air breakdown over an inch...
m
bi-wiring problem - explain?Hide this!Advertise here!
Transformer wiring problem ebenai Chip Amps 3 7th May 2007 07:56 PM
tranformer wiring problem ebenai Power Supplies 2 7th May 2007 09:35 AM
Basic wiring problem Bobhof Parts 2 22nd April 2006 03:51 PM
RCA - Minijack Wiring Problem Evan Robinson Everything Else 2 22nd March 2006 06:31 AM
Transformer wiring problem sumacSK Chip Amps 15 5th December 2005 12:59 PM
