Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Norton Internet Security 2006 - don't buy it!
Old 13th July 2006, 12:15 AM   #21
Cloth Ears is offline Cloth Ears  Australia
Cloth Ears's Avatar
Used to run AntiVirus Professional + Firewall (2003 edition? I think). Had no problems (and when bored, it was fun to trace the intrusions back to the source computer where they were initiated from). Don't have that PC any more, but I believe it's still working fine (friend still has it working).
Don't know anything about the current version, but it might be laziness (akin to Microsoft) causing the bloat.
VX Heavens indicates the sentiment expressed before (that the mainstream AV is what the majority of virii/trojans/worms are written to defeat) is absolutely correct. Most of them keep the latest copies on-hand to test against...
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 13th July 2006, 02:56 AM   #22
Christer is offline Christer  Sweden
Originally posted by EC8010
Yes, very nice. Now which is the bit we're interested in?
I am really no expert in this, but if I gave the right link you will first get to a page where you get info about what can be disclosed about you from your IP number. There should ideally be nothing there than can identy you or your computer, although it will usually tell something about what ISP (Internet service provider) you have.
Then if you click "Proceed" you get to the "Shields up" page, for testing the firewall and some other things.
The two tests that seems most interesting are
All service ports which scans the firs 1056 ports on you computer and tries to make contact through them. There are three possible outcomes. If a port is open, then probably anybody can contact your computer through it. In the worst case, there is a trojan listening for incoming calls. If a port is closed, it denies access, but the caller still gets a response that it is denied access. A hacker will then know that at least there is something at this IP address and might try to attack you. If a port is in stealth mode, your computer does not respond at all to incoming calls. If all ports are in stealth mode, it is impossible to know if there even is a computer at this IP address. A decent firewall should use stealth mode for all ports that are not authorized to respond to this particular caller, that is, all ports should be reported as in stealth mode.
Browser headers shows what info your browser sends to the places you browse. It should preferrably not reveal any personal info about you or your computer.
You may also try the Messenger Spam function, to see if foreign computers can send pop up messages to you. There is a freeware program, Shoot the messenger, on tha same site that prevents that.
There are some more functions. "File sharing" tries to see if there is a file server that can be accessed. I think it is trying to find a server for local networks, but I am not sure. Somwhere on the site there is also a program where you can "bake your own cookies" , ie. you can set cookies and tell yourself what content they should have. It is useful if you want to experiment with the cookie security settings in your browser.
Old 13th July 2006, 02:59 AM   #23
Originally posted by dr.strangelove3
Drive Image that was. Great program under win98.
On winXP machines it worked very, very slowly and you had to repair windows afterwards. On a XP machine ALLWAYS run the program from a repair diskette and not the dos mode. The program then wants to reboot in DOS mode, but somehow it locks up. Everytime I restarted it tried start Drive Image. After trying several things I was fed up with it and formatted c and reinstalled everything.
Right, that's it. I still have the program, but haven't tried it since I finally decided to move on to XP. Sound like I shouldn't try it either.
Old 13th July 2006, 06:04 AM   #24
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Christer, thanks for that. I will go away and experiment (carefully).
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 13th July 2006, 08:25 AM   #25
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Drive Image 2002(?) works perfectly on my XP SP2 machine. I only ever use the boot floppys though.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 13th July 2006, 09:08 AM   #26
ssmith is offline ssmith  Kenya
Originally posted by phn
Norton Antivirus is still the only antivirus program worth the name. People have always complained about it consuming computer power. But the other antivirus programs consume no computer power because they do nothing at all.
I disagree. I've been using Avast! Anti-Virus (Free) in combination with Spybot S&D, Spyware Blaster, ZoneAlarm & Adaware SE for close to two years now on 3 PC's I have at home, connected 24/7 to Internet. All of them have worked fine, and I see no reason to pay for Norton.
Old 13th July 2006, 09:16 AM   #27
Did it Himself
avast! has successfully blocked trojans coming on dodgy downloads and through scripted webpages, and removed viruses that AVG has not been able to (the boot time scan mode/option is very good).
It also seems to have a measure of anti-spyware as I run no anti-spyware software, yet on the occasions that I download the current top 3 packages I never have any.
Norton Internet Security 2006 - don't buy it!Hide this!Advertise here!
Panasonic security codes Tom7227 Car Audio 1 21st March 2008 11:17 AM
Digikey Website Security Issue BobEllis Everything Else 12 5th June 2006 12:35 PM
Lasers for security system polsol Parts 5 23rd November 2004 02:28 AM
Norton Internet Security - Blank topic UrSv Forum Problems 13 6th December 2003 05:29 PM
