Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 3rd June 2006, 02:02 PM   #1
Default reducing phantom power
Asked in another thread, but got no love, so I am trying my own thread
if I build a mic from the panasonic capsule... it needs 2-10v of phantom power. If I buy a preamp, like the the Behringer UB802... they give 48v.
So... do I just hook up a resistor? Digi-key specs say the capsules use 0.5mA max... so... 82k ohms * .0005 amps = 41 volt drop... which would bring 48v to 7v (somewhere in the middle of 2-10v)
good plan? bad plan?
Old 3rd June 2006, 03:20 PM   #2
moamps is offline moamps  Croatia
you might check out the schematics at
http://www.epanorama.net/circuits/mi..._powering.html
Milan
Old 3rd June 2006, 08:34 PM   #3
Great link, thanks moamps.
Man, why are things never easy?
I (and independantly, owdi) want to take speaker measurements... so there is a discussion about mic's and mic preamps ... and buying vs Diy, etc.
Main recommendation was Behringer ECM8000 mic + plus a Behringer pre-amp (say UB1202 or UB802).
I am a bit grumpy about $130 (ECM800 + UB1202 ), but agree that building a pre-amp is likely not worth it, when you can buy the 802 for $50.
So, I think $50 for pre-amp, and I build a mic from the Panasonic Electret Capsule for more like $15... and I can live with $65 total.
Then this mess w/ the mixed phantom power...
Basically, the website moamps references says "good freakin luck using just a resister, try this..."
Code:
                           10u
    +---------o-------------||------o-----------------  HOT    (2)
    |      CAPSULE                 22k
    |         |            10u      |
    |         o-------------||------|------o----------  COLD   (3)
   2k2        |                     |      |
    |        2k2                    |     22k
    |         o--330R---o----o------o------+
    |        10u       12V  10u
  --o---------o---------o----o------------------------  GROUND (1)
The component "12V" is a 12 Volt zener diode
(don't ask me what's w/ the extra new lines... [code ] tags are weird.)
There is some other version of the circuit there as well.
I suppose that is not too bad. Too my rather limited knowledge at least the components are cheap.
However, here is my question (other than the implied question of 'am I doing anything stupid?') ... what if I just skip phantom power altogether. I use a 9v battery (if even that much) to power the capsule and call it a day (still using a decent Behringer pre-amp, just not using a phantom powered input)
Any big reason to prefer one way vs the other (other than batteries running out, I guess...)
Old 5th June 2006, 03:31 PM   #4
I am still curious how people who built mic's out of panasonic electret capsules are giving them the 2-10v power.
Did you:
  • build your own pre-amp (I sorta suspect this is most common)
  • build a circuit to reduce 48v to 2-10v?
  • add a 9v battery to your mic, and run without phantom power?
Phantom Power might be Bad? mistermisfit Solid State 12 10th February 2010 08:22 PM
phantom power for condenser mic patknk939 Everything Else 5 21st September 2008 07:07 PM
DEQ2496 for phantom power? mazeroth Multi-Way 10 5th January 2006 04:51 PM
Using the phantom power Gabevee Instruments and Amps 2 29th July 2005 05:32 AM
Stripping Phantom Power Biffa Parts 5 19th May 2005 03:31 PM
Page generated in 0.09247 seconds (70.41% PHP - 29.59% MySQL) with 10 queries
