| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I got some queries on Eagle PCB Design Tools Version 4.15. Hope you can help. 1) May I know what is the difference between "hole" and "drill" layer in Eagle board layout? When converted to *.drd gerber file, both looks the same. I use GCPrevue for gerber viewing. 2) How can I increase the hole size because it is limited to 3.2mm in Eagle. I want to add bigger holes to mount PCB leg. 3) Why drill holes is not generated in *.drd files when I added a "pad" on the bottom layer. I need to add "hole" on top of pad before drill hole is generated in *.drd file. 4) What is the difference between "gerb274x.cam" and "gerber.cam"? GCPrevue cannot view files generated with "gerber.cam". It appears distorted. Thanks for your time. |
#2 |
Anyone pls....pls...
#3 |
#4 |
thanks
| The last tt alignment tool you'll ever need? | Conrad Hoffman | Analogue Source | 18 | 11th June 2009 06:47 PM |
| Need a tool! | Tenson | Multi-Way | 12 | 19th March 2007 08:36 PM |
| tool wearout | traw | Parts | 2 | 18th September 2006 04:08 PM |
| Help required in Eagle 4.16 Light Design Tool | Prasanna | Solid State | 4 | 19th March 2006 05:20 AM |
| Demagnetising Tool/Tool Demagnetiser | mrfeedback | Everything Else | 30 | 4th October 2002 11:53 PM |
| Page generated in 0.07891 seconds (70.90% PHP - 29.10% MySQL) with 10 queries |
