| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hi
Any idea about how much current I can draw up to with USB2...? I currently have an external 3.5" HDD with external mains PSU, but I want to get rid of that PSU if possible.... Do you think I could achieve this by having two USB connetors, one with Data+power connection and the other with power only..? Cheers, James |
#2 |
500 mA is the quoted USB spec AFAIK, per port.
The bigger problem is that 3.5" hard disks require a 5V and a 12V connection, at 1 amp each. 2.5" disks are a little more benign in their power requirements, and external cases using those disks don't need an external supply. |
#3 |
USB devices may draw up to 100 mA before "negotiation" with the host, after which they may draw up to what the host gives them permission to draw, which is limited to 500 mA due to physical interface requirements (USB cables, connectors, etc are designed for no more than 500 mA)
The negotiation requires exchange of information between the devices over the bus. I don't know what the standards for that exchange are. -- mirlo |
#4 |
IIRC, many 3.5" drives require 12 volts in addition to the five put out by the USB bus power. I would strongly avoid not using bus power for a 3.5" drive; you're likely to damage something.
Your best bet is to get an extension cable from one of your PC's internal Molex connectors, which are what are used for hard drives internally. Then, get it out to the hard drive, so that it can use your PC's internal PSU. |
| COD - Current Output DAC | BrianDonegan | Twisted Pear | 115 | 1st March 2012 07:15 AM |
| Reduce DAC output current ? | Bernhard | Digital Source | 1 | 10th January 2006 10:46 PM |
| increasing current output | xplod1236 | Solid State | 7 | 27th March 2004 06:24 AM |
| Page generated in 0.08898 seconds (63.52% PHP - 36.48% MySQL) with 10 queries |
