| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
hi
ok so my modded t-amps are up and running thanx to many here but now...what about the perfect transport? read Russ Andrews uses a modded laserdisc player for it's extra stability and general over-engineering for plain ol' red-book cds...but i am ignorant as a rock so, anyone know what ldps have digital AUDIO output that i can feed into a dac and play cds? ty from i miles |
#2 |
Hi Miles,
I'd use a good CD transport. Laserdisc players are optimized for ..... wait ...... here it comes ....... laserdiscs! A purpose built CD player is a much better bet. Some of the early NEC transports are great, I also like the KSS-151 (linear motor?) type. Even the lowly KSS-210A and 240A types put out a more stable eye pattern than some of the new ones. Easy to fix too. -Chris |
#3 |
A CD has nothing in common with vinyl. The information on a CD is interleaved.
The CD mechanism has no influence on CD playback. Vibrations, flutter are irrelevant. The FiFo and buffer take care of that. It's electronics and the laser that matter. Everything else is maketing. |
#4 |
Hi phn,
The transport has everything to do with digital errors. No comparison with a turntable has been made. I can say that the more stable the eye pattern is, and how clear it is directly impacts the quality of the information coming off the disc. You are getting an analog signal that is demodulated into a digital signal. Excessive noise will cause data errors. -Chris |
#5 |
I've used my Pioneer CLD-D704 Laser Disc player as a transport for
many years now. It has a Direct CD button for bypassing all video processing circuits. I've had no reason to update it, because i think i'd have to spend some serious money before there would be any improvement. If you can find one used it might be worth looking into... but i'm sure they're pretty rare now. Check out the new Rega Appollo... seems like a really nice CD Player. |
#6 | |
I'm not exactly sure about what you mean. But there's no noise in a digital signal. There are only "ones" and "zeros." The CDM has nothing to do with the analog signal. The only times the CDM comes into play is if it's broken or if the vibrations or chocks are severe enough to upset the laser. |
#7 |
Hi phn,
Been in digital audio service since it started. If you monitor the C2 flag, you can watch the error flags drop as you align a mechanism. The information comes off the disc (or tape) as an analog signal. If you reduce the amplitude, distort the wave shape or add noise, you increase the digital errors. So the alignment of the laser and pick up diodes is critical. This is seen as a change in the quality of the RF or eye pattern. If it's clean with the correct amplitude and stable, you will be able to extract and decode the information properly. If you send a demodulator garbage, you will get garbage out. You can try to correct it and reclock it as much as you want. Garbage is garbage. You have to realize that on a properly functioning transport with a good disc, there will be a certain amount of errors. That's called the BLock ERror rate (BLER rate). For other digital systems we can perform a BERT test to quantify the error rate. What I am trying to explain is that the signal is not a digital one until we demodulate it. What happens in the analog, RF realm is of critical importance if we want good sound. This means that you can not use a cheap transport and a great DAC and expect the performance the DAC is capable of. -Chris |
#8 |
many thanks, phn
nice clear knowledge is always better than cobbled together information, huh? what i was hoping was that i could use a cheap, used ldp and it would somehow run more stable with cds because of the higher speeds it has to use reading ld...and maybe an emotional reaction - the whole mech is bigger and beefier and that seems GOOD to my heart!! 'cos i'm into these t-amps at the moment - even though the low power has meant i ran it into clipping and blew my carefully crafted iplacoustic tml's drive units! - i'm in 'bargain basement' mode and want a weird industrial transport to use with a reasonably good dac. still not convinced that ldp isn't the way to go having drooled a little over Russ Andrew's test system but, ok... what machines have the best transports for, like, zero moolah? |
#9 |
I gotta say that my old Sony ES 508esd is a great transport. A great player too. It's built like a brick. The loader is metal as far as I can tell. It plays cdr's. It has more features than I know. It was cheeep, about 40 bucks USD on ebay in pretty new condition w/ orig box, manual.
regards, Marc
Crazy Yankee. |
#10 |
If you are looking at industrial players confirm that they actual play CDs before buying. None of the industrial players that I have seen do not play CDs (even those that will play the digital audio from a laserdisc).
All the domestic Laserdisc players that I have owned that were recent enough to have digital audio also played CDs, but some hi-end Laserdisc players were dedicated unit that only played Laserdiscs. I would think that many Laserdisc transports may actually be less stable than a decent CD transport when playing CDs as they often designed move to the other side of a Laserdisc to save the user from changing sides halfway through a movie. They also have to accomodate the different spindle sizes of Laserdiscs and CDs. |
| Need cross reference for Theta Data basic II Laser disc\cd player | gto127 | Digital Source | 16 | 21st October 2010 02:32 AM |
| Disc Table Height with KSS-Laser Units | Salar | Digital Source | 7 | 25th February 2007 11:58 AM |
| What cd players uses (used) this laser sf-p101 5/8 | helios999 | Digital Source | 3 | 19th April 2005 03:22 PM |
| Philips cd / video disc CDV 496 transport lock ? | Bernhard | Digital Source | 2 | 14th June 2004 09:28 AM |
| cambridge audio disc magic transport | NAP 160 | Parts | 0 | 10th August 2002 11:48 AM |
| Page generated in 0.11475 seconds (81.41% PHP - 18.59% MySQL) with 10 queries |
