Want to buy the Behringer ECM8000, have a computer, what else do I need? - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 31st May 2006, 09:10 AM   #21
Okay, maybe not 8
I was thinking I need 48v of phantom power, but apparently panasonic takes less than 10v... so just 1 there, instead of 5 And the plans call for 3 on the op-amp (which still seems rather extreme, meaning I am probably confused).
I really should try this just to, like... learn something
Old 31st May 2006, 04:12 PM   #22
owdi is offline owdi  United States
owdi's Avatar
Originally posted by Timn8ter
I have a barely used Behringer mic and mixer combo that I wouldn't mind parting with.
You've got mail.
Dan
Old 31st May 2006, 04:29 PM   #23
owdi's Avatar
If that's the case maybe you should buy. Pick your projects.
I'm going to dedicate what little time I have to finishing the cabinets for my current 2 way HiVi project, and worry about my measuring equipment when I am testing my crossover. If the deal with Tim works out, great. If not, I'll make do with the Radioshack meter.
To clarify, I am building a speaker where all drivers and crossover components combined cost less than $100, and I wanted to prepare my measuring setup for crossover design. Spending $130 on measuring equipment is worth it in the long run, but I've got other priorities right now.
As I understand them, the answers to my original questions are:
What kind of connector does the mic have, and what cable would I use to plug it into my computer? XLR, will not plug into computer
Does phantom powered +15v +48v mean it has batteries, or do I need to provide power? no batteris, preamp must provide phantom power
Do I need a preamp? My soundcard is a Hercules GameTheatre XP, which has a mic preamp and volume control knob, but I hear sound card preamps suck in general. Yes, a preamp is needed. Yes, soundcard preamps do suck. No, you cannot combine your soundcard preamp with a diy phantom power supply.
Dan
Old 31st May 2006, 04:32 PM   #24
Timn8ter's Avatar
A couple of you have emailed me about the mic and mixer I have. Unfortunately when I try to reply I get failure notices and your accounts here are not accepting messages.
Please try my other email address
info@alegriaaudio.com
The mic is the ECM8000 and the mixer is the Eurorack 602A. Both are in like new condition. I'm asking $50.
First come, first served.
Thanks!
Old 31st May 2006, 04:46 PM   #25
owdi's Avatar
Originally posted by Sillyboy
Okay, maybe not 8
You could also buy a small 12v SLA battery, they are pretty cheap and available at your local auto parts store. A cheap car battery charger is all you need to recharge, and a single charge should last at least a week.
Dan
Old 31st May 2006, 04:54 PM   #26
owdi's Avatar
Thanks!
$50 for both? I'll take it. danspublic AT gmail.com
Old 31st May 2006, 04:56 PM   #27
percy is offline percy  United States
Default Ub802
You need a Behringer UB802. At that price point there is no question it is a no-brainer. You will end up spending as much even if you "build" a decent one. Stay away from those "mic-preamp kits" if you intend to use this for serious speaker building/designing/measurement.
<edit:> ofcourse buying it used like the offer above is hard to beat!
Old 31st May 2006, 06:49 PM   #28
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Default Re: Ub802
Ahem. For what reason?
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 31st May 2006, 06:59 PM   #29
Ouch. Who could have known that Tim was gonna give such a sweet deal on the premap and mic? If other buyers don't work out, I am your man there.
Okay, let's just assume I get the UB802 at $50 (starting to sound rather worth it, though, I really do think I will build that $5 circuit at a learning excercise) ...
Question though, if I build a mic from the panasonic capsule... it only need 2-10v of phantom power, and the UB802 gives 48v.
So... do I just hook up a resistor? Digi-key specs say the capsules use 0.5mA max... so... 82k ohms * .0005 amps = 41 volt drop... which would bring 48v to 7v. That a good thing? or am I a 'tard?
Old 31st May 2006, 07:07 PM   #30
Default Re: Re: Ub802
Let's just assume he was referring to my retarded link to http://www.partsexpress.com/pe/pshow...TOKEN=70113254 which most likely sucks bad
Good kit's like your's from Mad About Sound are clearly excluded
Behringer ECM8000 question? Here-I-Come Everything Else 2 9th October 2008 06:18 PM
Behringer ECM8000 mic ShinOBIWAN Swap Meet 2 10th March 2007 04:46 PM
Aussies, Behringer ECM8000 mandoman Multi-Way 2 25th August 2006 05:48 PM
Behringer ECM8000 interface maylar Instruments and Amps 1 13th March 2004 06:17 PM
anyone want to sell used behringer ecm8000/preamp combo? kan3 Swap Meet 2 7th March 2004 11:10 PM
Copyright 1999-2017 diyAudio
