Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 30th May 2006, 02:08 AM   #11
jleaman is offline jleaman  Canada
Send a message via AIM to jleaman Send a message via MSN to jleaman Send a message via Skype™ to jleaman
Originally posted by metalman
Jason,
If you want to do it right, start with one of THESE , and add the Jon Rirsch filter suggested by Pierre G with the modification that I'd use a hybrid common mode choke such as recommended by muRata HERE, and I'd also snub the bypass capacitor on the outlet side.
Terry
I hope it helps with this problem.
Running a Balanced System, With Twisted X-BoSoZ
Baby Danika, Born January 20th 1:54am..
http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect..
Old 30th May 2006, 07:58 AM   #12
I see J Risch calls up 47nF (0.047u) for line to ground caps.
In the UK the maximum earth leakage on an RCD (RCBO) protected circuit is 25% of the trip rating.
Most systems are tripped at 30mA. This limits the total caps from line to ground to just under 100nF.
On that basis ALL the equipment on the same protected circuit should not exceed 100nF.
If you have suppression caps in other equipment then I suggest that the Filter caps to ground be reduced to either 22nF or even 10nF if your total is looking too big.
The Line to Neutral caps can remain at 47nF or even increased to 100nF.
regards Andrew T.
Old 30th May 2006, 08:39 AM   #13
Did it Himself
richie00boy's Avatar
Actually in the UK and Europe and likely the US too, any capacitors placed line (live or neutral) to earth must by Y-rated (open circuit in event of fail), and the total amount of capacitance allowed is 4.7nF.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 30th May 2006, 01:30 PM   #14
Hi Richie,
I cannot access the document that my 25% of tripping current came from, but can I ask where your 4n7F came from.
If your much more onerous figure were to be applied, it would imply that very little equipment could share the same outlet from a distribution board circuit. That would make most domestic installations illegal on the 4n7F limit basis.
regards Andrew T.
Old 30th May 2006, 01:42 PM   #15
Did it Himself
The 4.7nF limit is I suspect to ensure that multiple devices CAN be placed on a shared bus, yet still satisfy current and likely future RCD breaker standards.
I got my info from my year as a CE certification (included safety and EMC) engineer a while ago. The current standard at that time for appliance type equipment was BS-EN 60065 but I believe this has been superseeded.
Old 30th May 2006, 04:11 PM   #16
I wonder how hard it would be to build a ac power regulator. You know, like the one that monster makes and other comany's. They are complex i know that. Some start about 2500$ us each. They work well i was told. Would it be worth it to have tho is the next question..
Something like this ?
Old 30th May 2006, 04:31 PM   #17
Default Danger Will Robinson
Actually the 4n7 Y-cap is limited by safety considerations, because it links Live to Earth. Consider what happens if the equipments earth lead connection is defective. That's right, the casework could become live...
So - 4n7 limits the maximum leakage current to 0.3mA (at 240v AC); enough to give you a sting (it's about the perception threshold for AC), but not enough to cause serious hazard. And that's why, quite apart from breaker considerations, you musn't increase the value.
Have fun - safely!
Old 31st May 2006, 08:45 AM   #18
Hi
What happened to my thanks?
Was it removed?
Well Richie thanks again for that info.
As I said I'll go and do a bit more research, now that I have a starter.
regards Andrew T.
RC filters Sch3mat1c Parts 1 29th April 2011 09:34 PM
FM IF Filters Juergen Knoop Analogue Source 4 30th October 2008 03:35 AM
PSU filters kyrochan Power Supplies 1 2nd April 2005 05:05 PM
PI filters Prune Tubes / Valves 3 26th September 2004 10:16 PM
Filters Mr. Bungle Solid State 2 31st July 2004 06:08 PM
Page generated in 0.10073 seconds (76.50% PHP - 23.50% MySQL) with 10 queries
