Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 15th May 2006, 08:58 PM   #1
herm is offline herm  United States
Default Cutting Aluminum
I ran out of excuses for my lousy woodworking, so I decided
to try metal fabrication. This way I can make a bunch of mistakes
and blame it on lack of experience!
Here is my first attempt at cutting aluminum.
Before we even get started, must I remind you:
I don't mean to shock you, but this is what will happen to you
if you don't wear your protective gear!
All kidding aside, you will need Eye, Ear, and Respiratory protection.
I recommend the full goggle, rather than just glasses. As you will see
later, the aluminum bits fly everywhere.
Old 15th May 2006, 09:02 PM   #2
Clamps!
Make sure to clamp the hell out of everything. I clamped on both
sides of the cut.
Old 15th May 2006, 09:08 PM   #3
There will be aluminum flakes flying around, and you need to protect
you saw, too. Look closely at the air intake - I would hate to see the
result if you didn't use a nylon sock to keep chips out.
The cashier at the drug store had a strange look on her face when
I bought the nylons, though...
Old 15th May 2006, 09:11 PM   #4
The blade was a 10 inch, 80 tooth Freud carbide from Home Depot.
It specifically calls out "Non-ferrous metal" onthe blade. $55 or so.
Old 15th May 2006, 09:13 PM   #5
Of course, you have to use some form of cutting fluid. Here is what
I used...
Old 15th May 2006, 09:16 PM   #6
Here is a picture of the whole setup with a finished cut.
Old 15th May 2006, 09:16 PM   #7
Aengus is offline Aengus  Canada
Aengus's Avatar
I've always had decent success with a regular cross-cut blade on the table saw, and no cutting fluid. Not that a non-ferrous blade isn't somewhere on the desired-tools list - but it's not a necessity.
Those chips do fly.
Old 15th May 2006, 09:19 PM   #8
Here is a pic of the finished product. I am making a case for my power
supply, and this u-shaped aluminum seemed like a good way to go...
Old 15th May 2006, 09:24 PM   #9
Here's a link to a video.
http://www.ericherman.com/images/MOV01437.MPG
It's a pretty big file, so please be patient.
Any questions? Are you all brave enough to try it now?
The truth is, I have been researching this forever. Every one I talked
to said I needed a bandsaw. Finally I just tried it. You can see from the
video it cuts like butter. However, I did hide behind a large piece of
plywood the first time!
Old 15th May 2006, 09:52 PM   #10
poobah is offline poobah  United States
poobah's Avatar
You can cut 2" plate on a good tablesaw... just go slow.
Everybody keep in mind... you CANNOT do this with just any aluminum. You must use "free-cutting" grades. Purer alloys of aluminum are gummy and will not cut like this.
DAC cutting out malcontent Digital Source 10 2nd March 2007 10:19 AM
T-Amp Channel Cutting Out Diomedian Class D 16 16th February 2006 12:34 AM
Cutting MDF Vivek Everything Else 11 22nd February 2004 07:30 PM
Cutting Acrylic elizard Everything Else 22 11th February 2004 02:48 PM
Cutting a groove in Aluminum Jason_N Pass Labs 20 7th December 2002 11:16 PM
Page generated in 0.10507 seconds (78.11% PHP - 21.89% MySQL) with 11 queries
