Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 14th May 2006, 10:27 PM   #1
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Default Trying to learn Circuit maker
Trying to simulate a simple regulator.It works if I connect a battery after the rectifier.It is the trafo I can´t get to work ,and the mains in.how??
Regards Åke
Old 15th May 2006, 09:18 AM   #2
I'm not familiar with CM, but the circuit seems OK.
At a guess I'd say with the battery DC analysis works,
but DC analysis doesn't work with the AC input.
So I'm guessing you need to use AC analysis.
/sreten.
Old 15th May 2006, 09:58 AM   #3
Ryssen's Avatar
Well,I get no AC at the rectifier at all.
Regards Åke
Old 16th May 2006, 12:48 AM   #4
PM650 is offline PM650  United States
Perhaps you need to enter a turns ratio for the transformer? Thats about the only thing that I could think of.
Old 16th May 2006, 09:27 AM   #5
Ryssen's Avatar
I have now entered the trafo ratio,and if i dissconnect the bridge I get
22v ac out from the trafo,it is when i connect the bridge i get zero.It says timestep to small. How do I fix that?
Regards Åke
Old 16th May 2006, 11:36 PM   #6
Hi Ryssen,
You can try a 1000k between secondary and ground and /or use more realistic diodes for the bridge,
or You download from here
http://www.linear.com/designtools/so...gistration.jsp
Lt-SwitcherCAD.
Here You find many examples/tutorials:
http://groups.yahoo.com/group/LTspice
Heinz!
Old 17th May 2006, 05:55 AM   #7
Ryssen's Avatar
Didn´t work with the resistors,it´s sommeyhing with the diods.Even tried with one 1N4004,nope!
There is a ac before the diode.
Regards Åke
Old 17th May 2006, 11:24 AM   #8
lndm is offline lndm  Australia
Ryssen. I too have had problems with transformers in cm. I don't know what it is. If you remove the transformer and replace it with the sig gen adjusted to what you expect the secondary voltage to be, you'll be right.
If you want to incorporate leakage inductance and DCR, you'll need discreet components.
Old 17th May 2006, 04:14 PM   #9
Ryssen's Avatar
If I remove the diode bridge and connect a batteri instead it works,I´ll
be running bateries herafter.
Regards Åke
Old 17th May 2006, 06:26 PM   #10
AlexK is offline AlexK  Russian Federation
Ryssen,
There is a mistake in the schematic - transformer's primary should NOT be connected to groung.
Hope this helps.
Alex.
Circuit Maker <<questions>> bogdan_borko Solid State 23 24th January 2011 10:31 AM
Convert formats beteen Eagle/Circuit maker Ryssen Everything Else 0 1st August 2007 11:49 PM
circuit maker library help... Flavio88 Solid State 1 2nd September 2006 04:08 AM
Triode spice models for Circuit maker bogdan_borko Tubes / Valves 3 15th August 2006 12:38 AM
Problem in Circuit Maker 2000 xitronics Everything Else 0 4th December 2005 08:04 AM
Page generated in 0.13435 seconds (68.73% PHP - 31.27% MySQL) with 11 queries
