Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 12th May 2006, 05:40 PM   #1
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
Default ultrasonic sensors
i'm still trying to make a distance measuring device , so i've desided to use ultrasonic sensors ....
does someone know how to translate the transmitting spl level to effective distance the sensor can be used?
for example transmitting spl is 120db
what is the max usable distance for the sensor?
if you are not living on the edge you are taking too much space
Old 12th May 2006, 08:53 PM   #2
dnsey is offline dnsey  United Kingdom
I can't answer your question specifically, but it's probably longer than you expect. A few years ago, I was designing a low-powered ultrasonic alarm, and couldn't understand why the receiver kept showing an output when nothing in the room was moving. Eventually I traced it to the doors, about 10m away, swinging in the breeze by about 1cm!
Old 13th May 2006, 01:28 AM   #3
jcx is offline jcx  United States
http://www.acroname.com/robotics/inf...nar/sonar.html
from google search: polaroid ultrasonic sensor
also
http://www-personal.umich.edu/~johan...rs/paper93.pdf
and lots more
sonar/radar equations are well known but complex, what's your directivity, target scattering coeff, receiver sensitivity, ect.
experimentation is much easier than accurate modeling - judge feasibility by reported performance of similar systems
Old 16th May 2006, 02:36 PM   #4
clem_o is offline clem_o  Philippines
Transmistting SPL can't be directly translated to max distance. You need to factor the medium losses, the reflection loss (this is determined by the impedance difference between the medium and the reflecting surface) , the receive sensitivity, the beamwidth of the transmitter, among other things...
Cheers!
Old 16th May 2006, 02:42 PM   #5
A little off topic (but only slightly): There seems to be a convenient single-chip solution available that doesn't need much additional hardare apart from PSU and sensor.
I can try to find the type of this IC if you are interested.
Charles
Ultrasonic Cleaning?????? grhughes Tubes / Valves 25 7th March 2009 01:31 PM
force sensing resistors pressure sensors foam/sheet/DIY VvvvvV Parts 5 8th August 2007 10:24 AM
Temperature sensors in an amp rtarbell Parts 6 30th July 2006 04:59 AM
Ultrasonic heaters DHT112A Tubes / Valves 53 10th June 2006 11:59 AM
iCube(X) System + Sensors (for custom MIDI interface) (trade for Evolver) skiptracer Swap Meet 1 26th May 2006 02:28 AM
Page generated in 0.08291 seconds (71.67% PHP - 28.33% MySQL) with 10 queries
