diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Everything Else (http://www.diyaudio.com/forums/everything-else/)
-   -   Professional EQs in Home Audio (http://www.diyaudio.com/forums/everything-else/78711-professional-eqs-home-audio.html)
Ric_LV 1st May 2006 11:49 AM
Hello
I have recently bought a Rane SEQ30L eq for DJing purposes. But I must say, that when I tried to use with my home stereo (I have DIY speakers and 2x300w @ 8ohm monoblock amps. A russian brand KIT, but sounds good!) I was amazed of the power of that EQ! The best result I had, was with Iron Maiden Rock In Rio CD (live). If I leave the signal untouched and hear the music at HIGH volume, then all I hear is the screaming of fans and the three sologuitars mumbling somewhere. The solo-singer (Bruce Dickinson) was like a backvocal. Plus, the sound was really a pain - screech. In other words - chaos! But when I adjusted some of the 30 EQs sliders, I received a clear sound, I could hear every guitar, the crowd was there but was not so annoying and the solist was actually a SOLIST! Smile I wanted to say, that you can achieve a good sound with a simple thing we all know. And that thing is called EQ. Any comments?
Nigel Goodwin 1st May 2006 12:55 PM
Re: Professional EQs in Home Audio
Originally posted by Ric_LV
Hello
Graphic EQ is used to balance your complete system, including speakers AND the room. To set it up you should apply pink noise, use a precision measuring micrphone and a spectrum analyser - and adjust the graphic to give a level response. This should give you the optimum sound.
Ric_LV 1st May 2006 01:26 PM
By Ear
There is also an option, a lot cheaper - adjusting the EQ by ear. :) I use EQ to make the music sound more enjoyable - screechless, chaos-free and so on. And till this day it works! I have many records which lack bass or have too loud mids or highs. Some old recordings lack high frequencies. For example, to add more feeling to the techno music, I don't gain the whole "LOW" knob on my DJ mixer, like most Djs do, because it gains the whole low part from 25-160 or 200 Hz. Instead of that I gain only the 30-60 Hz on my EQ and it sounds a lot better. Deeper. Cooler. If I play a rock song on a party (for ex. Guano Apes - Open your Mind or Rammstein - any song) there is always a screech comming from the speakers, because at high volumes, the sound in a 2000-3000 Hz range gets too audiable and it kills the music, because all you hear is the screeching guitars and no singer at all. In this situation I usually cut 2kHz and 2,5Khz sliders and gain 1Khz and 1,25Khz (but it all depends, you gotta hear it!). A frequency that is quite pleasent at high volumes is 300-500 Hz, I usually gain that a little if necesary. This gives the music it's powerfulness, pretty much like bass, but with more tone. And it is all done by ear! :)
Copyright 1999-2017 diyAudio
