Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 18th November 2002, 06:36 AM   #11
frugal-phile(tm)
planet10's Avatar
One of the locals powers his 1875 gain-klones with pairs of sealed motorcycle batteries. Works great...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th January 2003, 06:15 AM   #12
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
well, as an update, almost all the work is done for the battery supply for my NAD cd player. i have finished all but the relay network and the wiring needed to switch the setup from a 12v over to a 36v.
here are the details:
there are 3 12v 5AH sealed lead acid batteries hooked up in parallel when charging. the charger is actually a velleman kit (the intelligent lead acid charger). it works very well, and is very efficient. its powered by a 40VA xformer. however, when the player is kicked on, the charger disengages, and the batteries are then kicked over to be hooked up in series, thus providing 36v.
it will be kinda slick once im finally done with it. just need to get the relays and wire them to the batteries, everything else is done and tested. the things took a whole 18 hours to charge from start to finish. 15AH total between them. should be MORE than enough for the cd player. (i use my equipment a lot...)
ill post pics once i get the relays setup (hopefully tomorrow).
as per the advice of kiwi_abroad, i am going to add master kill switches to the back of the box. when those are off, the batteries will be completely disconnected from the system, just in case you ever needed to unplug it for awhile.
oh, and im still curious what value of caps i need to lower the impedance at higher frequencies. im not an EE, and quite frankly i SUCK at electronics, so i really dont know what i need to do here. help maybe?
Old 30th January 2003, 08:54 AM   #13
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
bypasscaps for battery PSU.
The complete circuit can be found at http://thunderstoneaudio.nav.to/
Hope this helps
Mads K
Battery-powered supplies vic2 Chip Amps 246 16th August 2010 04:07 PM
What is the story with battery supplies? jteef Solid State 6 20th November 2006 01:06 PM
I did a search on battery power supplies, but... Septimus Chip Amps 96 15th March 2005 01:27 PM
Battery Supplies RichardJones Pass Labs 1 12th June 2002 08:53 PM
Battery Power Supplies Jason Hubbard Solid State 21 9th September 2001 05:38 AM
Page generated in 0.10399 seconds (53.35% PHP - 46.65% MySQL) with 11 queries
