| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I have made a TT sub-chassis out of some clear Perspex and would like to paint it, probably black. Can I just use an acrylic top coat or should I use an undercoat aswell.
It is only going to be a working prototype but I would like a decent finish. Google just brings up artist materials and the only manufacturers site I found just said use a suitable paint (!), anyone any ideas? TIA, Paul. |
#2 |
I think you will need a key for most paints to stick. Some may have a solvent that interacts with the acrylic and thus produce a key. Arcylic is available in black. Do you have any offcuts you could experiment with, 600/1200 wet or dry silicon carbide paper will give a very fine keyed surface but use wet and ensure you and your working surfaces are clean to avoid scratching. Do you realise you can polish your cut edges? progressive wet/dry followed with an abrasive brass polish.
regards Andrew T. |
#3 |
Cheers Andrew,
I dont know if I was imagining it but I was sure I read on here that someone "glued" 2 bits of acrylic together using acrylic paint. Needless to say I cant find the post now. Thats why I wondered if I could just use top coat, perhaps it reacts with the plastic?? |
#4 |
artists use acrylic gesso as a primer usually white but can get black too. Very rough when dry so must be sanded to desired smoothness.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#5 |
acrylic paint is a water based paint. It will have little solvent content. I suspect it will not react with an acrylic sheet. But worth trying.
regards Andrew T. |
#6 |
if you want the coatings to adhere well..and realtively permanent..then rough the plasic up with 600 grit or better. jsut rnough to say the surface is 'micro' roughed. Make sure it is clean of oils. and yes, acrylics are usually a 'water based' coating.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge. "Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti |
#7 |
Cheers Guy's, I didnt realise it was water based. perhaps I am thinking of 2 pack acrylic auto paint...that has plenty of nasty chemicals in it.
I suppose I could also try enamal paint, as used on plastic model kits. I used model glue to stick the 2 bits together. I'll have root around the shops tommorow and report back. Paul. |
| Painting aluminum | CarlyBoy | Parts | 15 | 14th January 2007 08:35 PM |
| painting | flux01 | Multi-Way | 10 | 7th July 2006 04:36 PM |
| Painting the speakers | jmiyake | Multi-Way | 21 | 30th December 2002 01:55 AM |
| Help!!!! Need Help With Painting! | slicemaster101 | Subwoofers | 10 | 19th April 2002 08:03 AM |
| Page generated in 0.09033 seconds (75.90% PHP - 24.10% MySQL) with 10 queries |
