Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 1st April 2006, 03:19 PM   #1
karma is offline karma  Canada
karma's Avatar
Arrow industrial screws in wood
im using industrial screws to hold the top on my psu. thay fit and i used the right sized bit. what im asking is there anything i can put on the threads to help them turn out better?
any ideas?
Old 1st April 2006, 03:21 PM   #2
pinkmouse's Avatar
What do you mean by industrial screws?
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 1st April 2006, 03:22 PM   #3
karma's Avatar
Default .
Old 1st April 2006, 03:25 PM   #4
Speakerholic
Cal Weldon's Avatar
What do you mean by turn out? Is that the same as removing? If so try waxing them. You can do this with an old candle. Wax it, screw it in, remove it and do it again. This way you will some wax inside the thread of the blind nut.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 1st April 2006, 03:25 PM   #5
karma's Avatar
this type not really sure what there called. i had them given to me
Old 1st April 2006, 03:26 PM   #6
anatech is offline anatech  Canada
anatech's Avatar
I think I see a Marantz something on the lower right there Karma.
What Al said. Do you have a pic. of the hardware by itself?
-Chris
Old 1st April 2006, 03:27 PM   #7
karma's Avatar
sorry i was in a hurry im working on it now
ok i will try wax
thanks
Old 1st April 2006, 03:29 PM   #8
karma's Avatar
-Chris
ya a working tapedeck you want it its free
Old 1st April 2006, 03:30 PM   #9
Speakerholic
Cal Weldon's Avatar
If it's cold, you can use a lighter or torch to warm the bolt a bit.
Old 1st April 2006, 03:36 PM   #10
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Did you tap the holes in a wood?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
industrial music for industrial people Stan Gielewski Music 45 8th October 2008 04:34 PM
Industrial 12V PWR supply to be used with T-amp kanaddict Class D 31 1st August 2005 10:23 PM
Do I have to use screws busterno1 Multi-Way 8 10th February 2004 08:58 PM
Page generated in 0.29615 seconds (29.47% PHP - 70.53% MySQL) with 11 queries
