Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 1st April 2006, 10:44 AM   #1
Default A/B testing switch
I'm going to build a switching box for speaker and amp comparisons.
I could do a simple 2 directional system. In one direction it will switch one amp between 2 speakers, in the other direction it will switch 2 amps into 1 speaker.
But I have some questions.
For amp testing, is it overkill to switch between speaker and a dummy load to keep the other amp working ?
I saw an amp switching box described somewhere that commoned the -ve terminals. Is that safe for all amplifier designs?
Old 1st April 2006, 11:07 AM   #2
Default Re: A/B testing switch
Yes it's overkill, there's no need to use a dummy load on a transistor amlifier, however a valve amp must not be used without a load.
It's NOT safe for bridged amplifiers, and will damage it, so I would suggest switching both to be safe.
Nigel Goodwin
Old 1st April 2006, 11:36 AM   #3
Pretty simple then.
DPCO (dual pole changeover)
30V, 8A
should do the job ?
Old 1st April 2006, 11:40 AM   #4
just realised, I don't know how relays work.
does a changeover relay latch in either direction and you apply a burst of either +v or -V to choose which way it is switched ?
Old 1st April 2006, 12:09 PM   #5
No, it's one way without power, and the other way with power. Although you can buy special latching relays.
Nigel Goodwin
Old 1st April 2006, 12:24 PM   #6
I've just worked out than I will get plenty of hours testing from a set of rechargeable batteries, so that's no problem.
Never try to switch 450V DC at 3A with a conventional mains switch... Eva Power Supplies 28 1st November 2006 09:24 AM
A simple A/B switch for testing. Taperwood Class D 11 9th May 2006 06:19 PM
A simple A/B switch for testing Taperwood Full Range 5 7th May 2006 06:05 PM
Question: I need to build an AB switch for testing speakers Taperwood Full Range 19 23rd March 2006 10:03 PM
Page generated in 0.09530 seconds (66.06% PHP - 33.94% MySQL) with 10 queries
