diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Everything Else (http://www.diyaudio.com/forums/everything-else/)
-   -   looking for a certain type of switch (http://www.diyaudio.com/forums/everything-else/76839-looking-type-switch.html)
Catfish45 31st March 2006 02:15 AM
I am looking for a power switch like you would see on the xbox 360 and some logitech speakers. The kind that lights up around the button and maybe has the i/o on it also. It needs to be for 120v. I'm sure if I found this switch it would be momentary, I need one that when pushed is on, then when pushed again it is off. I'm sure I could use a relay or something to turn a momentary switch into a simple on/off switch. this is the closest I have found http://www.performance-pcs.com/catal...roducts_id=784
Thanks!
-Rob
Stocker 31st March 2006 03:15 AM
Try NKK. They seem to have it all, if all you need is a switch. Also consider the possibility of using a lower-rated switch to activate a power-on relay.
Catfish45 1st April 2006 08:21 AM
looked on their website, and emailed rep, they have no switch like what I am looking for.
Stocker 4th April 2006 03:34 AM
google image search
You sort out the copy/paste action. It's too late for me to figure out why these aren't working right, but I found all these with Google's image search, you could too. HTH. I couldn't find the illuminated center metal one on EAO's webpage but if you call them maybe...
http://www.frozencpu.com/images/prod...lr%3D%26sa%3DN
http://www.alliedelec.com/Search/Pro...&IND=T&SEARCH=
http://www.alliedelec.com/Search/Pro...I001%2F28%2FRD
http://www.epn-online.com/images/edi...lr%3D%26sa%3DN
http://www.eao.com/EAO/servlet/eaoKa...psid=261&jmp=1
http://www.electromechcomp.com/produ...=12&ITEM_ID=14
Much cheaper
http://www.microcenter.com/image.pht...lr%3D%26sa%3DN
http://www.schurter.ch/products/switch_new.asp
Resources saved on this page: MySQL 18.75%
