| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I wasn't exactly sure where to post this so it's going here. I was shopping around for some computer parts, when I came across a SoundCard manufacturer by the name of Auzuntech, who are making a couple soundcards which have large parts on the PCB. In fact, they have all the op-amps in DIP sockets! All you have to do to swap an op-amp is pop it out and pop the new one in. No solder required. I found this to be very cool on a commercial product, so I am spreading the word. They look like a real solid product as well. Rage3D has a review of the X-plosion 7.1 card, with high resolution photos of the board. The op-amps installed are S4580P
The power of Science compels you! |
#2 |
Dammit these guys stole my company's name! ARGH!!!! I had the name first, and I own the domain name. Those bastarrdds!
#3 |
Woops, I spelled it wrong both times I types it. Should read Auzentech.
#4 |
it's still MY company's name
#5 |
Indeed this card will be very well suited for those ones that enjoy swapping op-amps and coupling capacitors.
It employs a single-chip solution, with all DACs, ADCs, analog mixer, PCI I/O, digital I/O, etc... sharing the same package and supply rails like in $15 soundcards. And it also has DIP sockets to allow modders to play their favourite game with exotic op-amps, each of which will cost far more than the own chipset of the sound card! |
#6 | |
It's better than a Creative sound card for some parts! (If we don't consider the mostly unuseful EAX that almost all the processor power is dedicated to) -There's live DTS and DD encoding, something that only expen$ive software would normally do, not even Creative cards... (Maybe live DD on the X-Fi tho) -It seems like the only good alternative to Creative cards with SPDIF inputs(M-Audio doesn't have some)! -Swappable opamps and dual supplies, can put almost anything in there! -I think that it's not always re-sampling also. And it has hardware sound support, not M-Audio. Cons : -The bad thing is the 16/48 ADCs, but the SPDIF in supports 24/96. - $140 - The X-Fi will give you Live DD I think, 24/96 recording(Dunno if it's more than stereo), 24/192 playback (With no more resampling in "music mode") It would need a bit more I/Os, maybe hardware DD/DTS decoding, better ADC/DACs(Probably just a Crystal IC a few steps up would be able to do this), and other things like that to make me happy.
Antoine http://dmsaudio.ca/ |
#7 |
they have a new card called meridian coming out "soon" with better spec all through
4 pcs 24-bit/192kHz AK4396VF (120dB-part spec.) DACs for 7.1channel output. (24-bit/192kHz in 7.1channel playback) and swappable opamps for the outputs. depending on the price, i might swap out my 0404 for this. |
#8 |
wonder if its possible to cut traces leading to the power tags on the PCI card connector, and pipe in some clean power of your own....
#9 |
Auzentech is one step ahead of us. The meridian already has it's own regulated power supply.
Of course it isn't "pure" as a direct connection to the A/C source, but it does well with the original SMPS signal. If you can't already tell, I'm a big fan of these cards and can't wait for $$$ and slap my BBs in there.
ERTW 4 life! "the day has 24hours. If that is not enough take the night."-Roemhild |
#10 | |
| Soundcard or Dac? | imperfectcircle | Digital Source | 36 | 13th June 2008 02:00 AM |
| Any Super -T amp modders? | ROBSCIX | Class D | 4 | 3rd February 2008 07:03 PM |
| U.K Modders missing a trick ?! | Puffin | Class D | 27 | 2nd October 2007 08:24 PM |
| CD-753 - only for seasoned modders | capslock | Digital Source | 0 | 1st August 2004 07:32 AM |
| Pure Delight | Alain Dupont | Pass Labs | 107 | 8th February 2004 02:48 PM |
| Page generated in 0.15200 seconds (64.62% PHP - 35.38% MySQL) with 10 queries |
