Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 22nd March 2006, 03:47 AM   #1
Default RCA - Minijack Wiring Problem
I just made an RCA-minijack cable and am having problems with it.
I wired it in this fashion:
Minijack TRS: Tip - Left channel, Ring - Right channel, Sleeve - ground
RCA Left: Centerpin - goes to tip of minijack, Ring - goes to ground (common with right RCA connector at the minijack, they are soldered together)
RCA Right: Centerpin - goes to ring of minijack, Ring - goes to common ground
My multimeter shows connections to the proper places and no shorts.
The problem is this: Only the left channel works. Did I wire this incorrectly or what could be the issue?
Thanks.
Old 22nd March 2006, 03:55 AM   #2
lgreen is offline lgreen  United States
lgreen's Avatar
Default hmmm
I've done this a few times (example). Your wiring scheme is correct (tip=left, ring = right, other part (base) = ground). Sometimes the minijack plugs can be no good, they are super cheapo quality. Once I had a new one from digikey and it measured open circuit to the ring to all leads no matter what I tried. So check the tip-to-lead and ring-to-lead connections (better yet to the end terminals). If these are good it should work.
Or else your source is mono and not stereo, in which case you know what to do!
My DIY audio projects- PartTimeProjects.com.
Old 22nd March 2006, 05:31 AM   #3
I guess next time I should triple check. Turns out the ring solder terminal in the minijack was just barely touching the sleeve causing a short. Ugh. I had to use a cheaper minijack than I wanted to because I accidentally ordered a mono minijack instead of stereo. Thanks.
bi-wiring problem - explain? mantisory Everything Else 3 17th July 2006 07:39 PM
Transformer wiring problem sumacSK Chip Amps 15 5th December 2005 11:59 AM
Zappulse PSU wiring problem ewildgoose Class D 31 31st October 2004 02:30 PM
need solution for wiring problem... I think Predsy Car Audio 8 30th July 2004 12:07 PM
A wiring thought problem Xylenz Multi-Way 9 23rd January 2003 04:58 PM
Page generated in 0.43634 seconds (14.26% PHP - 85.74% MySQL) with 10 queries
