| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hi Everyone, here is another little resistor/voltage puzzle.
Say I have 3 resistors, R1, R2, R3. I wish to calculate the voltage at the center where all 3 connect together. On the outside of the 3 resistors, I have V1, V2, V3. What's the formula? Example: V1 = 0v, R1 = 22K V2 = 5V, R2 = 18k V3 = 10v, R3 = 90k How do I solve for the voltage of the other side where all 3 resistors short together? What if I have 4, of 5 resistors?
_______ Brian |
#2 |
that must be impossible to solve (unless you have worlds's most powerful computer to make a model simulation)
even with only 3 resistors and 3 voltages do like this 1. hook it up, 3 voltage supplies and 3 resistors you will need 2. measure with voltmeter from 0V to the joining point of resistors this will give a correct result
lineup |
#3 |
@lineup: no it isn't imposible to solve. & will wait 30 more minutes before working out the solution.
Here is a hint: You must work out the parallel total resistance first, then plug use it to solve a multiple voltage/current divider.
_______ Brian |
#4 | |
#5 | |
maybe .... ... a simulation spice program will solve it in a moment they have some formulas programmed ... or is it just repeated corrections in a loop, until a good, satisfying value is reached?
lineup |
#6 | |
Bingo! Here is the formual. First, solve total resistance, I'll call it Rt. Rt = 1/ ( (1/R1) + (1/R2) + (1/R3) ) Then plug in the voltages, I'll use Vt for total voltage: Vt = (Rt*V1/R1) + (Rt*V2/R2) + (Rt*V3/R3) For more resistors, just increase the R# & V# in the pattern of the above formulai.
_______ Brian |
#7 |
Is it that easy.
I think, even I, now know how to solve this sorta puzzle. Not that often, at least in amplifiers, we need to find out voltage in 3 resistors crossing point, with 3 different voltage sources. But I know one case where this happen. This is in a sound mixer input. Often 3,4 or more resistors are connected to mixer Op-Amp inverted input pin. Each coming from a sound channel.
lineup |
#8 |
http://www.physics.northwestern.edu/Lab/ec_c.pdf
I have found the above link very usefull to get to grips with alot of these calculations... seeing that school was a lifetime ago... it all comes back reasonable easy though, but then again, I always liked science. |
#9 |
what result did you calculate for the voltage at the junction. I got 3.468V. but your posted formulae gave 8.441V which is clearly wrong. Tell us, which is correct?
regards Andrew T. |
#10 | |
When you say 'calculate', AndrewT, what you mean? You used a simulation? And got 3.468V Calculate is for me using math, as with a mini calculator. Anybody with access to a circuit simulation program, will not need any formulas to calculate. I never use any circuit simulations. Just my head or my pocket calculator and paper and pen. So for me a general useful and correct formula would be interesting. Regards
lineup |
| How to lower mains voltage using resistors | johnm | Tubes / Valves | 14 | 13th June 2008 07:41 PM |
| Should I use high voltage value zeners or multiple lower voltage zeners in series? | jarthel | Parts | 7 | 30th May 2006 04:56 PM |
| Emitter resistors in multiple BJT output stage | bocka | Solid State | 37 | 8th October 2004 11:58 AM |
| Multiple drivers in same enclosure & resistors for attenuating tweeters | bm_mode | Multi-Way | 4 | 14th October 2001 02:21 PM |
| Page generated in 0.14237 seconds (68.75% PHP - 31.25% MySQL) with 10 queries |
