Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 2nd March 2006, 10:27 PM   #1
percy is offline percy  United States
Default Battery powered PC ?
Has anyone tried - or know of anyone who did - doing away with the smps in a typical desktop pc and replacing it with a complete battery based supply ?
Old 2nd March 2006, 10:30 PM   #2
karma is offline karma  Canada
karma's Avatar
i guese you could but it would be a lot of work.
hmm i got one to spare ill try it.
Old 3rd March 2006, 01:16 AM   #3
The PC psu has +3.3, +5, -5, +12 and -12 outputs. Some of these are at very high currents.
Sequence is also important.
Power input is so high that even car batteries don't power a UPS for long.
If you want battery supply use one of the low power ITX boards or a laptop.
Old 3rd March 2006, 01:29 AM   #4
if you are saying that based on what ratings are stamped on your psu then you are not on the right track.
but I can understand where you might be coming from. Older CPUs used 5V are their primary voltage, so older psu have huge 3v and 5v current rating and meagre 12v rating. Newer CPUs use 12V. so as long as you have a good (10-12A) +/-12V line and barely half of those amps on the 3 and 5v lines it should be just fine.
I will try to find an interesting link that gave a very good idea of power supply requirements for a pc.
<edit:>
here it is-
http://firingsquad.com/print_article...rticle_id=1162
Old 3rd March 2006, 09:13 PM   #5
have you worked out any design plans ? would be good to discuss if you're interested.
Old 4th March 2006, 12:28 PM   #6
Bakmeel is offline Bakmeel  Netherlands
Bakmeel's Avatar
Default The Solution:
It is called "Laptop"... Your very own, off the shelf, battery powered PC!
They make those thingies so compact now, you can even carry them with you! Isn't that wonderful?
More Power Igor! More Power!
Old 4th March 2006, 12:37 PM   #7
Send a message via AIM to DigitalJunkie
I ran an AT style (P-200overdrive,IIRC) PC from a 17AH selaled lead acid battery for quite a while one day..
Crude 12V PC PSU
Old 6th March 2006, 12:27 PM   #8
sangram is offline sangram  India
Actually it's quite possible, there are these little SMPS units that can deliver about 100 watts from a 12V battery, easily found on sites that deal with car PCs and stuff.
If you're thinking full linear supply, yes, it's possible, but you'll require lots of regulation and heatsinking unless you're looking for a very small PC (like a P200 overdrive), those things will not require more than 60-70 watts which would translate into 3 hours from a single 17AH battery - assuming no other losses, so you could probably squeeze a 2-hour runtime out of a single charge.
The one thing I could think of something like this is for an 'audio PC' that dispenses with any HF nasties like an SMPS would put out - but it's quite a bit of trouble. A Laptop isn't a solution because the LCD screen is driven by a very noisy SMPS itself. And sois the rest of the electronics... For everything else though, it is the best solution.
Old 6th March 2006, 12:35 PM   #9
Maybe you could run the 5V and 3.3 lines off a 6V SLA and the 12V off a 12V SLA. For the negative lines a single battery with some 79xx regs should be enough.
Remember even if you run everything off a linear supply, the main CPU Vcore regulators are switching regulators, not linear so you'll still get a bit of switching noise...
Old 6th March 2006, 12:37 PM   #10
karma's Avatar
not at the moment. come spring when the college students go home ill work something out. im sure i could do it but there right it would use up allot of batterys. you could set it up in a car. if thats what your looking for.
Battery powered XO? MikeHunt79 Solid State 2 17th March 2008 03:19 AM
Battery powered amp Shpoop Chip Amps 8 26th January 2007 04:41 PM
anyone using a battery powered pre? whatsnext Solid State 15 30th October 2006 12:26 PM
battery powered gc in a tin digi01 Chip Amps 11 25th December 2004 05:11 AM
DC-33 DC Battery Powered Amp?? moe29 Pass Labs 2 26th April 2004 07:41 PM
Page generated in 0.10932 seconds (78.57% PHP - 21.43% MySQL) with 10 queries
