Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 6th March 2006, 12:32 PM   #11
percy is offline percy  United States
Originally posted by sangram
..this is for an 'audio PC'
most likely yes
Old 7th March 2006, 03:37 AM   #12
however does it (quality and type of power supply) really matter if you are simply extracting digital audio (from spdif) on the motherboard or soundcard to an external dac ?
Old 7th March 2006, 06:08 AM   #13
sangram is offline sangram  India
Actually, it would matter most then. When it would probably not make too much of a difference is if you have a good soundcard with SPDIF and/or you pull the digital audio through USB, which is better than a two-bit sound chip that is used on most motherboards.
I would get a good card with digital out, preferably an entry-pro level card like the audiotrak Maya or the m-Audio Audiophile, and I wold have probably spent less than battery + linear reg + heatsinking and cooling, as these are available around the $150 mark, and don't have issues of heat and/or noise.
I have two digital outputs on my PC, one from the motherboard and the other from my m-Audio delta, and there is a SQ difference between the two. Quite a bit actually.
Old 7th March 2006, 06:27 AM   #14
dfdye is offline dfdye  United States
dfdye's Avatar
Interestingly, our electronics shop guys are making a full linear PSU for a computer to get rid of noise for a computer running a VERY sensitive instrument. The instrument is so sensitive to noise, it is going to be housed inside a full room sized faraday cage! (Imagine copper mesh for as far as the eye can see!!!)
The PSU is still under development, but if you are interested I can see if they would be willing to share the schematic for general use.
Old 7th March 2006, 06:47 AM   #15
Ouroboros's Avatar
You can get the low-power VIA Mini-ITX PCs with a 12V PSU option. These are sometimes used if you want to put a PC in a sailing yacht to provide the navigation computer.
Although the fastest VIA mini-ITX board is only 1.3GHz, they are very small and high quality boards. Have a look at www.mini-itx.com for ideas.
Old 7th March 2006, 07:24 PM   #16
yeah thats the idea, it would be either the soundcard spdif OR the motherboard - or a pci-usb card - usb port, depending on what DAC I end up building.
Currently I have a Turtle Beach Santa Cruz which isn't bad and also has spdif output.
Would love to see it!!
Battery powered XO? MikeHunt79 Solid State 2 17th March 2008 02:19 AM
Battery powered amp Shpoop Chip Amps 8 26th January 2007 03:41 PM
anyone using a battery powered pre? whatsnext Solid State 15 30th October 2006 11:26 AM
battery powered gc in a tin digi01 Chip Amps 11 25th December 2004 04:11 AM
DC-33 DC Battery Powered Amp?? moe29 Pass Labs 2 26th April 2004 06:41 PM
Page generated in 0.13538 seconds (70.03% PHP - 29.97% MySQL) with 10 queries
