| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I have a 25-year old toroid which I don't know the VA rating of.
IT is the Transductor brand with a label saying number 6050. My memory tells me it is a 300VA, but I am definitely not sure about this. Comparing its physical dimension some modern toroids of varying brands it matches those of 200 - 225VA. Intuitively, this seems a reasonable way to determine the rating, so can I assume it is approx. a 200VA one? Edit: Hm, guess this one should have gone inte "Electronics and Parts" instead, but never mind. |
#2 |
Electrons are yellow and more is better!
If the weight is 2.7-3.0 kg it's probely a 300 VA. 300VA from Toroid Transformer(former Transduktor) nowadys weiths 2.55 kg including the metal "rondell" (round disc).
BTW: Christer, isn't this thread a typical "Electronic Parts"?
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#3 |
Thanks Per-Anders,
unfortunately I don't have the weight of it since it is mounted in lab PSU I built some 25 years ago. I am afraid I would not get this messy thing back into working order if trying to take out the transformer to weigh it. On the other hand, this PSU has never been working very well and the reason I want to know the transformer rating is that I plan to redesign the PSU from scratch and reuse parts from it. I didn't know that Toroid is former Transduktor, but now I had a look at Toroids web page, and indeed they are using the old Transduktor logo. |
#4 | |
#5 |
diyAudio Senior Member
No coloured insulation on the secondaries? Regards,
Frank |
#6 |
Yes!
Green-Red, Brown-Blue
#7 | |
they? Anyway, the secondaries are red-blue and red-green. |
#8 |
Sorry,
No answer on this from me. The enlightened Sir Anders may be helpfull in this? ROTMFLAO. Cheers,
Frank |
#9 |
Christer, to make it easy, compare a modern 300 VA of brand "Toroid Transformer" with the one you have got. The modern one is slightly smaller, not much.
#10 |
Banned
But better than nothing.
This chart is for stacked lamination transformers. I believe that at one time, we empirically decided that a toroid was good for about 50% more VA capacity. Jocko |
| estimating ripple current rating | earl of sodbury | Parts | 16 | 6th June 2008 10:54 AM |
| DIY driver - estimating Le | el`Ol | Multi-Way | 3 | 5th December 2007 06:44 AM |
| Estimating power output | dsavitsk | Tubes / Valves | 21 | 13th April 2007 02:48 AM |
| Estimating choke size ? | woody | Tubes / Valves | 2 | 6th December 2006 06:53 AM |
| estimating max continuous spl of a speaker | tech.knockout | Multi-Way | 4 | 30th March 2004 01:01 AM |
