| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Purchased Adcom 555 on E-Bay. Apparently a previous owner had a cat that used the amp as a marking post. How do I clean the circuit boards and other areas of the amp without doing any more damage? Should I just return the unit to the seller due to the cost and complexity of the cleaning?
#3 |
holy crap netlist!
and I thought my two fisted tuner-spray/shop-vac method was pretty extreme. |
#4 |
Great Idea !
However I would dunk the amp in a final bath of demineralised water in a tub . That would make sure that any residual water droplets would dry without leaving any residue . Keeping the amp warm for 2 days might depend on how dry the weather is. In a place like ours I would leave it in the sun for a week or even more. We do have a very humid climate - most times. I've done this with two DMM's and both survived and work well ! I dried them in a baking oven kept at very low heat - I checked the temperature before putting the meters inside. They had a few presets on them. No problems. You could blow air into presets and other moving parts in case you think there might a lots of water trapped inside and then dry them. Keeping it in an oven or heater might be tricky. You should ensure the temperature doesn't go over say 50 deg C. Some caps have a 85deg C max rating . So elevated temepratures might cut down on its lifetime. Any experts out there on temperature ?
AM |
#5 |
My problem may be cat markings that flowed into the amp.
#6 |
That indeed might be a problem. If not cleaned properly and instantly you might find some pcb copper traces in real bad shape.
Check for that first. /Hugo |
#7 | |
Cleaning the board / insides must be on TOP of your priority of things to get done. I think it is acidic and can really eat up things ! Clean it will soapy water. Use any liquid dish wash detergent. I would brush it on with a 1 inch wide paint brush. Try to keep the water and soap to the areas concerned - if possible. Otherwise wash well and spray clear with distilled water and dry for a " few days ". You could mop up with an absorbent cloth / paper in areas that are accessible easily. Blow drying a bit will also help get most of the water out. How would I know ?........ It happened to my scope ! Yeah , the scope works fine. Not my cat , the neighbour's cat !
AM |
| alw regulator circuit boards | fmak | Solid State | 1 | 3rd December 2008 04:11 PM |
| Circuit boards, another dirty way to do! | destroyer X | Solid State | 75 | 21st January 2005 06:53 PM |
| Cleaning Aleph X Boards | kilowattski | Pass Labs | 24 | 1st January 2005 05:35 PM |
| Aleph2 Boards spring cleaning | harvardian | Swap Meet | 4 | 14th April 2003 01:13 AM |
| Zen circuit boards for sale. | pixie | Pass Labs | 0 | 9th February 2001 04:22 PM |
| Page generated in 0.12019 seconds (67.56% PHP - 32.44% MySQL) with 10 queries |
